Author Topic: Can i swap ecu's over 96 16v  (Read 2577 times)
Offline mat-ryder
« on: 01 June 2009, 13:14 »
I think my ecu on my abf is shot and i wanted to know if its possible to swap the ecu and key over from my other abf. do i just need the chip from the key and the ecu?
Re: Can i swap ecu's over 96 16v
« Reply #1 on: 01 June 2009, 13:56 »
Yes plus I think you will also need the ring around the ign. switch.
Offline azzrobz
  • Mk3 GTi 16v Anni
« Reply #2 on: 01 June 2009, 14:01 »
you dont seem to be having any luck with ur abf m8  :undecided:
Offline cs98sss4
« Reply #3 on: 01 June 2009, 18:30 »
You can swap just the ECUs but it will need adapting using VAGCOM or other.
Golf MK3 16V ABF "Anniversary"
Offline VW Mel
« Reply #4 on: 01 June 2009, 18:32 »
Could swap it over, wth the ign ring and key.
Why do you think its your ecu? Have you had it looked at?
Offline mat-ryder
« Reply #5 on: 02 June 2009, 01:37 »
I have tried everything, its really starting to p!ss me off now. I replaced the crank sensor today cos the wiring on it was shot. i need someone with vag-com to plug it in. i did buy a lead but i can get the drivers to work on it, tried everything once again. when i swapped the ecu before without the ring it would fire up for a second so it makes me think its the ecu....
Might go and buy a vr6 lump and be done with it
« Reply #6 on: 02 June 2009, 10:05 »
you need the transponder box, key and ecu. ring doesnt hold anything special so that can be left alone.
Offline mat-ryder
« Reply #7 on: 02 June 2009, 23:14 »
What do i need for a vr6 conversion?? :laugh:
Offline danny_p
« Reply #8 on: 02 June 2009, 23:25 »
don't think you need the transponder box.i have 3 diffrent ecu's and they all work through the same loop and transponder box  just the rfid chip in key that matters
all the VW's have gone bar 1.
« Reply #9 on: 03 June 2009, 08:16 »
if you swap key and transponder box along with the ecu it doesnt need recoding with vagcom, mat says he cant get it vag-com cable working so needs to do it this way ;)
Also says with ecu swapped car starts then dies which is an immobilisor fault.
I beleive if you just swap ecu you can recode the matched key and transponder box to the new ecu as cs98sss4 said :)
edit: I saved this text from clubgti somewhere, this is how you adapt a transponder box to an ecu apparently:
Quote
To Adapt Immobiliser:
Go to 'Immobiliser' Module in VAG-Com,
'Adaptation'
Then 'Read'
Wait a few seconds, and press 'Save'.
To Adapt ECU:
Go to 'Engine' Module in VAG-Com,
'Adaptation'
Then 'Read'
Do both...and all works well.
I've swapped them about many times. Never a problem.
This just seems to mate the immobiliser to the engine ECU.
« Last Edit: 03 June 2009, 08:21 by rubjonny »
