Sounds like a massive vac leak to me....... check for splits in the hose from the metering head to the throttle body and all interconnecting hoses, also it could be a failure of the overrun cut off valve under the back of the airbox, if that fails or the elec supply to it fails then it breaks the vacuum. The pipe connections under there are iffy at their best, vibration may have shaken them loose. If you're unsure about the cut off valve, disconnect it underneath where the pipe goes into the main hose and block off the hole into the main hose and see if the engine runs. The engine does not need this unit connected, it just stops overrun when the engine is hot.
