Golf mk2
Flashing coolant level light (tried the usual suspects)
Topic: Flashing coolant level light (tried the usual suspects) (Read 17145 times)
hobbes
Re: Flashing coolant level light (tried the usual suspects)
Reply #10 on:
09 June 2009, 08:55 »
Oil temp is from the MFA right? if so, my MFA doesn't appear to work, it just gives a blank figure. The only thing on it that does seem to work is the outside temp but when it was 23 C the other day mine told me it was 6 C....
Mk2 Golf GTI 16v
Mk4 Golf GT TDI
james_16v
GTI forum regular
1986 Golf GTI 16v
Reply #11 on:
09 June 2009, 10:43 »
Yeah oil temp is from the MFA, it doesn’t register until its above 50 degrees though but if its still showing ---- after its warm check that the wire hasn’t fallen off the sensor. It’s on the back of the head on the right hand side as you look at the car. I have no idea where the outside air temp sensor is though.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #12 on:
09 June 2009, 10:58 »
if you pull the relay the temp gauge will work as normal, it only disables the level sensor
beechymonza
mad beech
Reply #13 on:
09 June 2009, 17:58 »
the outside temp sendor is fitted inside passenger side front wing, i dont ave a 43 relay, mine is a 42 above fuse box
No guts No glory,
beechymonza
mad beech
Reply #14 on:
09 June 2009, 18:37 »
sorted, after 9 years of flashing, pulled relay 42 out, an its done it,i cant believe it, i been askin ages about this, and i seen loads of other folks askin about it, and it was so simple all along, wish i could find proper solution though
No guts No glory,
james_16v
GTI forum regular
1986 Golf GTI 16v
Reply #15 on:
09 June 2009, 18:50 »
Well done mate!
It feels great to drive without that damn light on.
With mine im sure its the relay that is at fault as ive changed everything else.
Im in no hurry to replace it though just glad its stopped.
beechymonza
mad beech
Reply #16 on:
09 June 2009, 19:13 »
cant believe it, i even thought about gettin a small drill bit an drillin the bulb through at 1 stage ,
No guts No glory,
Golf mk2
