Author Topic: Someone else with gearbox noise!  (Read 1041 times)
Offline seismic22
« on: 31 May 2009, 12:28 »
The gti hasnt long gone over 100k and i have recently been feeling a rough rotational feeling through the floor combined with if i listen hard a rough rotational noise. Initially i thought it was just doing it under v.light engine braking, rolling in gear etc but now i can hear and feel it when its under throttle. Although it does it everytime i drive the car the noise/ feeling through the floor is not constant and comes and goes with different speeds. Saying this i can only ever hear or feel it if im doing less than 50mph.
To me it sounds like gearbox bearing but i am unsure and am hoping it something else.
This may sound like im clutching at straws but my friend said that he had a similar noise/feel throught the floor when his centre box was blowing on his mk3 polo. Well my centre box is now blowing quite considerably and when thinking about it the noise through the floor (albeit under my feet and obv further in front of the centre box) has increased in feel/noise over exactly the same time period as the centre box's blowing has.
I know from experience with other cars and wheel bearings and drive shafts etc that noise gets transmitted around cars in weird ways and is often misleading but am i as previosuly said clutching at straws hoping the centre box could be the noise/feeling or are the symptoms just classic mk3 gearbox bearings going?
Like previous posts i have written an essay, so sorry, but any help would be appreciated! cheers! :smiley:
MK3 GTI 16V. The fun starts at 3.5k.
Offline seismic22
Re: Someone else with gearbox noise!
« Reply #1 on: 31 May 2009, 14:01 »
also! other than change the centee box as soon as poss im probs going to try drain the gearbox and refill it with some new stuff. was thinking about putting some slightly thicker stuff in, is this a good idea and if so what thickness should i use? cheers
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 31 May 2009, 16:19 »
Hm, i went through all of this, changed the gearbox, CV Joints... turned out it was a rear wheel bearing,  start with the simple ones,  chances are you will be lucky!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline seismic22
« Reply #3 on: 01 June 2009, 21:10 »
any ideas guys?
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 01 June 2009, 21:14 »
get the exhaust fixed as that noise will echo under neath the car and if there is another noise you won't find it easy! but I also recommend some new (pref synthetic) gear oil as this cures all sorts of issues with the crappy mk3 boxes! don't use thicker oil or total failure will be rapid!...syntetic is best but even new oil is better than what you'll have
Offline seismic22
« Reply #5 on: 02 June 2009, 09:05 »
Thanks boney, will do!
