Author Topic: Problem with my Brakes!  (Read 1062 times)
Offline funkyfive
« on: 31 May 2009, 10:19 »
I recently bought a GTI 8v, on closer inpection i noticed that the sensor and the lid were loose on the brake fliud reservoir.
I re-seated them and a light comes on the dash, i checked vag.com with no errors.
What i noticed;
When the sensor is clipped in fully, i get a light on the dash
When the sensor is not clipped in, i get a light on the dash
When the sensor is resting in but not fullly clipped in, no light on the dash.
Its seems to me to be a points issue with the sensor not seating correctly?
Whats your thoughts???
How can i fix this? Do I just need to clean them, if so? or do i buy a new brake fluid reservoir?
Offline spunkymonkey
  • Tepidly moist! That's what that is!
Re: Problem with my Brakes!
« Reply #1 on: 31 May 2009, 11:02 »
I zip tied my contacts apart, both my vr6 and 8v had the same problem. I wouldnt bother about it.
Offline funkyfive
« Reply #2 on: 31 May 2009, 11:38 »
Strange to ask do you have a pic as i just wondering why have you done that? Surely this is to inform you off the level of the brake fluid??
VW BUSH
« Reply #3 on: 31 May 2009, 11:53 »
Is the little cap missing that holds the plunger down?
If so this will be your problem, i found a cap at work and cable tied it down
« Reply #4 on: 31 May 2009, 11:59 »
That was the problem with mine.
It is but i just keep a close eye on it and all is good.
Offline funkyfive
« Reply #5 on: 31 May 2009, 12:05 »
No, the cap and plunger are fine. I think its the points on the inside of the sensor housing on the fluid reservoir.
VW BUSH
« Reply #6 on: 31 May 2009, 12:17 »
Go down to Audi/VW at Angmering (or Retro VW at Chorley) and pick up new one (Cap that is)
Should cost a few quid :wink:
