Author Topic: Rear Top Mount Advice  (Read 2107 times)
Offline Manxmann
« on: 29 May 2009, 23:07 »
Hi Folks,
Just after another bit of advice. A little while ago I decided the valver needed lowering as it was looking a bit silly with standard springs and 17" wheels.
Now bearing in mind that I only paid £150 for the car and I'm already down the cost of Bilstein gas shocks / bushes all round I couldn't entertain even a cheap set of coilovers.
Looking around I found a set of 40mm lowering springs from a company called Essex Racing which where reasonably priced so went ahead and bought them.
Yesterday I fitted the front two springs and was very pleased the fit and finish is great and the ride improvements quiet astonishing for such little money.
Now the problem, I went to fit the rear spring tonight only to find they don't fit, the overall diameter of the spring is about 5mm too small to fit over the inner locating 'cup' of the top plate.
The springs are clearly marked 'Golf Mk3 Rear' so don't think I've been sent the wrong set.
What options do I have, ideally I'd like to get some replacement rear top plates with a smaller centre location cup, that way I can keep the springs I have. It also saves me having to take the fronts off to send them back  :wink:
Any advice appreciated.
Tar
« Last Edit: 29 May 2009, 23:22 by Manxmann »
Offline Mikester
  • Civic Type R
Re: Rear Top Mount Advice
« Reply #1 on: 29 May 2009, 23:11 »
If i remember correct the mk3 came with 2 different sized cups depending on year, as i have seen threads about this problem before. Cant remeber, but will have a search for you mate.
Offline Manxmann
« Reply #2 on: 29 May 2009, 23:22 »
Cheers Mikester appreciate that.  :smiley:
Offline shepgti
« Reply #3 on: 29 May 2009, 23:23 »
think this came up recently, like mike said the ealier gtis (up to 94??) had larger pig tail top plates.  but are you fitting the springs to the bilstein shocks?? :undecided:
« Reply #4 on: 29 May 2009, 23:26 »
The fronts are 100% different early and late, just checked http://www.vagcat.com/ and they only have 1 rear plate listed, might be the wrong springs maybe.
Offline Manxmann
« Reply #5 on: 29 May 2009, 23:30 »
Is this really bad? :shocked:
I'm sure I read you can go to 40mm on standard shocks without too many problems, reduced shock life being the only real issue.
It certainly drives a darn site better than before.
I'm worried now  :undecided:
Offline shepgti
« Reply #6 on: 29 May 2009, 23:33 »
no is fine dont worry, was just confused by your original post as you mentioned bilstein shocks which will have a standard size top plate whereas standard mk3 shocks may be differnt.
« Reply #7 on: 29 May 2009, 23:33 »
Lowered springs should really only be fitted shocks that have a shorter travel, will be fine in the short term however.
Offline Manxmann
« Reply #8 on: 29 May 2009, 23:35 »
Cheers Wayne, I new the early Mk3 had what amounts to Mk2 front mounts.
Hmm not good about the rear mount only showing 1 listed, as I say the springs have 'Golf Mk3 Rear' marked on them. Guess I'll be calling them tomorrow to arrange a return.  :sad:
Are the rear mounts the same for all Mk3's? i.e. what about the non GTi/VR6 (Should that be lesser  :grin:) models
« Reply #9 on: 29 May 2009, 23:36 »
Yes all the same.
