Author Topic: Fuel leak on a full tank  (Read 1175 times)
Offline james_16v
  • 1986 Golf GTI 16v
« on: 29 May 2009, 19:43 »
Noticed a smell of fuel the last 2 times ive brimmed the tank after short journeys.
Had a look today under the car and there was a small patch of petrol under the tank that had dripped down the side.
Im not overly concerned as the smell goes away when the tank gets to about 3 quarters full.
Anybody know the likely problem?
Offline Agreeable Slick
  • Unit
Re: Fuel leak on a full tank
« Reply #1 on: 29 May 2009, 21:21 »
Lift tank access point is probably leaking.
Offline james_16v
  • 1986 Golf GTI 16v
« Reply #2 on: 29 May 2009, 22:23 »
Thanks for the suggestion.
Is there a seal or gasket around the lift pump that needs replacing that would cause this?
Offline Bjork
« Reply #3 on: 31 May 2009, 16:18 »
Did you find the cause mate?
Mines doing same thing but can't find it.
