Author Topic: Ed30 problems electrics , windows, trip meter zeroing by itself?  (Read 2282 times)
Offline Steve30
  • Ed30 .
My car has some problems with the windows not closing properly through the key fob, also the trip meter keep's zeroing itself, and every now and then the alarm goes off? :shocked: I dont really want to go into the dealers last time they damaged my car (dent in wing). It was fixed by them bloody inconvenince though. The car 58 plate 6000 on clock ? support needed thanks Steve30 . :cry:
Tiguan quicker than the Golf
Offline bacillus
If you don't want to go to the dealer in the first instance then I suggest you get someone to scan the car with VCDS to see if that pinpoints the fault.
Ultimately, I suspect you will have to let the dealer sort this out...
Without traction power is nothing!
Offline Steve30
  • Ed30 .
I think your right, but i'm reluctant!! Can I call out VW breakdown and ask them to sort it out? Thanks Steve30
Offline ifti
Im as reluctant as you when it comes to the dealers!
Offline TagnuT
  • Edition 30
Try a different dealer. Some are much better than others. :smiley:
Bye Bye Edition 30
Offline bacillus
Unless the car is immobilised in some way I don't think they would attend.
Offline Simon ED 30
My dads passat had the same problem as this a few months ago, after much messing about and 8 days at the dealers they ended up putting a new central computer, 4 new door sensors and two new door locks into the car. Hope you get it sorted
Offline Steve30
  • Ed30 .
I went in the dealer's today, they found nothing wrong with the windows and trip meter, but there is a problem with the igniton coil which they going  repleace under warrenty on wednesday. They said no other fault codes came up , except a lose battery conection? But I know for a fact it was'nt tat lose!! Thanks guys Steve30 :undecided:
Offline richGTI
Also electricial problem on Ed30,auto locking keeps locking & unlocking by itself for about 5 times.Seems to happen when weather is hot?
