Author Topic: 8v to vr6 conversion  (Read 7433 times)
Offline Mikester
  • Civic Type R
Re: 8v to vr6 conversion
« Reply #20 on: 29 May 2009, 14:50 »
Costs about £100 to get it de-imobilised. And i defo wouldnt try it yourself.
And horney... im not used to being so elite that i have 6 cyclinders. Naturally i type 4! lol
Offline lukesgti8v
« Reply #21 on: 29 May 2009, 17:46 »
Its reallu not that hard of a conversion, the driveshafts are the same and even the loom plugs straight in. go for it mate!
Offline Tuccy
« Reply #22 on: 29 May 2009, 21:29 »
Great the help and advice on here is greatly appreciated. Thanks everyone
the ignition issue,
can i just use the vr6 ecu loom etc, then replace the 8v transponder reciever under the dash/collum
with the vr6 one,
then
remove the chip from the vr6 key and put it into the 8v key, this way i would be using the 8v key mechanism, barrels, keys etc, but the key chip would be transmitting the vr6 info to the vr6 reviever behind the dash/collum??? ( Surely this would work ok??) :undecided:
anyone??? lol
im a mechanic and a good with electronics/electrics etc so im quite comfortable, however im a vw virgin :rolleyes: so learning the tech stuff...
yeah i have vag com..
also why shouldnt i attempt the de-immobilising??? (although hopefully i wont need too)
is it possible for the diy`er?? :laugh:
Offline Mikester
  • Civic Type R
« Reply #23 on: 29 May 2009, 22:51 »
You can do exactly what you said and it will work.
But simplier is just to duck tape the VR6 key inside the steering column trim. As it will be close enough to the transponder all the time....
Up to you if you want to fart about with the keys or not really.
« Reply #24 on: 29 May 2009, 23:29 »
the ignition issue,
with the vr6 one,
then
anyone??? lol
Yes that will work fine, you could tape the vr6 key inside the column however you might issues with both keys being coded and may lead to it not starting.
« Last Edit: 29 May 2009, 23:31 by Wayne »
Offline G40VUW
« Reply #25 on: 09 June 2009, 18:37 »
i am thinking of this conversion, is that really true u can just plug a vr6 lump straight into an 8v with no wiring? am i being a bit stupid thinkin i can do this with not much knowledge about cars and help from friends?
« Reply #26 on: 09 June 2009, 20:34 »
Much easier with a donor car, you still need the engine loom / ecu plus a lot more.
Offline G40VUW
« Reply #27 on: 09 June 2009, 21:08 »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=220430303644
would this be any good?
and is it true u have to weld engine mounts?
« Reply #28 on: 09 June 2009, 21:47 »
Not really as its a Passat and lhd.
Offline G40VUW
« Reply #29 on: 09 June 2009, 21:59 »
glad i asked the guy said it would go straight in, cheers for answering my questions im gunna try find someone local whos done it to do more research b4 i go digging myself a big hole :)
