Author Topic: 16v big probs  (Read 1380 times)
Offline mat-ryder
16v big probs
« on: 28 May 2009, 00:35 »
My problem from last week has escalated and now i cant even start my car. Its fouling up the plugs almost instantly when trying to start. i replaced both problem relays a few weeks ago and vag com said i needed a new lambda so its had a new one of them recently too.
anybody know what would cause it to dump fuel like that??????
HELLLLPPPPPPPPPPP
cheers all
Offline grimmer
  • www.check-light-on.co.uk
Re: 16v big probs
« Reply #1 on: 28 May 2009, 23:04 »
ect sensor, wrong lambda sensor, be careful when buying a lambda theres a couple of different types
MK3 GOLF GTI 8V  now converted to 16v!!
Offline mat-ryder
Re: 16v big probs
« Reply #2 on: 29 May 2009, 12:11 »
It was working fine with the new sensor, iv even tried disconnecting it and it still doesnt work.  :sad:
Offline apollo996
Re: 16v big probs
« Reply #3 on: 29 May 2009, 16:36 »
I had a similar problem with mk2 8v.  The ecu was faulty causing it to overfuel/flood and not start
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
Re: 16v big probs
« Reply #4 on: 29 May 2009, 17:47 »
yep hes right sounds like ecu mate ive seen it b4 on a 16v
.....the project.........
Offline Pete Taylor
Re: 16v big probs
« Reply #5 on: 29 May 2009, 19:17 »
Or possibly the fuel pressure regulator, wouldn't show as a fault on vag com
Offline mat-ryder
Re: 16v big probs
« Reply #6 on: 30 May 2009, 22:08 »
will the ecu fault show on vag-com?
I have tried swapping the ecu with another one but the immobiliser chip stops me from starting it. Anyway to bypass it?
Offline apollo996
Re: 16v big probs
« Reply #7 on: 01 June 2009, 21:18 »
Hi, with my ecu fault the fuel pump kept going rather than just prime itself prior to ignition.  Do you hear your fuel pump stop and start?
