Author Topic: Fuel Leak !!!  (Read 1734 times)
Offline Philboy
Fuel Leak !!!
« on: 27 May 2009, 22:34 »
Got home tonight and the woman tells me she can smell petrol form the car :huh: so i  pop the bonnet and from what i could see no problems. took a look underneath the car and i've got fuel pissing out of the fuel filter  :angry: I've been told it's a ten minute job. i  had a go earlier and can't get the fuel connectors off. Any ideas?
AUM R-tech magic dust
Offline bobbarley
  • I'm kind of a big deal...
Re: Fuel Leak !!!
« Reply #1 on: 27 May 2009, 23:04 »
IMPORTANT - You need to de-pressurise your fuel line before you disconnect anything!  Remove fuse 28, the start the car until it conks out.
The connections are a bit weird, but they do just click on and off once you get the hang of it.
Offline K666PDP
Re: Fuel Leak !!!
« Reply #2 on: 28 May 2009, 17:38 »
and the DRIVERS door when opened primes(turns on) the fuel pump!! so get in thru the passenger door or disconnect battery(defo do this anyway).  :wink:
Offline bobbarley
Re: Fuel Leak !!!
« Reply #3 on: 28 May 2009, 18:20 »
Just pulling out the fuse and running the car until it conks out is sufficient, no need to faff with doors or the battery.  Trust me, I've done it :)
Offline Philboy
Re: Fuel Leak !!!
« Reply #4 on: 28 May 2009, 19:03 »
Ok still having trouble with these connectors surely there must be a tool to take these off? I feel like i'm gonna break them if I pull any harder!
Offline bobbarley
Re: Fuel Leak !!!
« Reply #5 on: 28 May 2009, 19:17 »
You don't just pull them.  There's a bit that you push in at the side, then they just pull off easily.
Offline Ant1981
  • Feed me, prod me
Re: Fuel Leak !!!
« Reply #6 on: 28 May 2009, 19:18 »
If it's pissing out of the filter, depressurisation is already taking place.
'09 Kawasaki Ninja ZX-6R
Offline Philboy
Re: Fuel Leak !!!
« Reply #7 on: 28 May 2009, 20:11 »
Right all done  :smiley: nice one for all your help
