Golf mk1
MK1 brake upgrade help
Topic: MK1 brake upgrade help (Read 4117 times)
macca99
Just got here
27 May 2009, 20:49 »
got a mk1 gti as per the brakes are crap
im looking to put mk2 gti brakes on her but id like to know what i need
carriers/hangers
calipers
discs n pads
anything else and would they go straight on the front?
caddyrage
GTI forum regular
Re: MK1 brake upgrade help
28 May 2009, 09:31 »
Ideally, you need to find some carriers from an old audi 80(think thats the 1) as the bolt spacig is the same as mk1 golf jetta caddy(75mm). mk2 gti carriers have a greater bolt spacing so they wont fit although you can use the calipers(256mm) with the audi carriers. There is adaptors out there to run G60 280mm brakes but you'll need minimum 15in wheels(ats cups wont fit either). I have the audi brake set up on my caddy using 256mm brembo disc's and pagid fast road pads, much improvement over stock.
There is a few people now resorting to fitting vauxhall brakes due to cheapness of the conversion.
You could just fit the larger 22mm M/C and servo from a mk2 gti/b3 passat and then just upgrade your pads to race spec types
03 ibiza PD 130 sport, smiles per miles!
83 mk1 golf gti, 16v 2L PL
92 mk1 caddy, now stripped for resto
WWW.FENDUBBERS.CO.UK
cambridgeshire vw owners club
wayders
GTI forum regular
Built by the germans, thrashed by the british!
28 May 2009, 19:15 »
I have the Vauxual SRI conversion for sale if interested??
M
cristiano
Just got here
30 May 2009, 05:54 »
Hello there.I have an information for all of you.There is a few people now resorting to fitting vauxhall brakes due to cheapness of the conversion.You could just fit the larger 22mm M/C and servo from a mk2 gti/b3 passat and then just upgrade your pads to race spec types.Thank you.
___________________
floatingtank
bodybuilding supplements
DOA
31 May 2009, 21:28 »
^^ Forum hack? Check the other posts hes done and his links.
maaarcooose
GTI forum regular
06 June 2009, 09:35 »
I replaced all the pads, brake lines, fluid, rear brake shoes, drums an bled the whole thing properly and my MK1 brakes are great now.
Consider it before doing a full conversion.
!m!
Golf mk1
