Golf mk3
hardmonkeys
Jerking problem - please help
Topic: Jerking problem - please help (Read 878 times)
hillary2005
Just got here
27 May 2009, 20:00 »
Not had my golf long now but its started jerking
It only ever does it when its warmed up and then starts jerking and hesitating quite badly. After a second or 2 it sorts itself and goes again but everytime you slightly move the accelerator it does it again
Just wondering if anyone has any ideas on what it could be?
Thanks
christomk3gti
Re: Jerking problem - please help
28 May 2009, 00:10 »
petrol filter maybe blocking... spark plugs nackerd.... could be anything really, best start at cheap things tho, u should get one of those Vag-com as it could show up a problem... worth a try.
Black 8v GTI............. Whats a Waffle Valve?
mumbles
28 May 2009, 00:13 »
thought this thread was going to be about something totally different for a moment there
"Jerking problem - please help"
HAHAHA!!
as for advice, get it on a vag com if you can. check leads, plugs, one of the temp sensors...
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
jamie16v
Guest
28 May 2009, 00:17 »
what car?..
if 16v check the hoses going between inlet manifold / Fuel pressure regulator / and map sensor
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
28 May 2009, 08:05 »
Mabey it needs a mate?
ehem... anyway could be something along the vac lines, mabey fuel.. process of elimination me thinks.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Golf mk3
hardmonkeys
