Author Topic: Odd tyre wear on fronts  (Read 2950 times)
Offline Davey
« on: 26 May 2009, 13:08 »
I've just had 2 front tyres fail on me within 500 miles of each other due to very odd wear. Both tyres looked fine with good tread all the way accross and about 5mm left but both wore right through at the botoom of the inner sidewall. I cant think what would cause this. I thought tracking but had that checked and it was spot on. The car had done 12500 and 13000 miles at the points of failure and I do lots of short trips and car park manouvering mixed in with occasional longer trips. Both tyres failed during long motoway trips.
Any ideas what would cause this?
Thanks
Offline ub7rm
Re: Odd tyre wear on fronts
« Reply #1 on: 26 May 2009, 13:17 »
Bet they are Dunlop Shytemax's?
If so thats the (common) problem with this tyre.  Bin them.
If not... can't help!  :drool:
2020 BMW 128ti
2017 Golf GTD Estate
Offline smartypants
« Reply #2 on: 26 May 2009, 13:26 »
+1 as above :D
Offline Cass
« Reply #3 on: 26 May 2009, 14:39 »
I'd take the tyres back to the suppliers/fitters and ask that they be returned to the manufacturers. They could be part of a faulty batch. Only way is to seek a response from the manufacturers and the best way to get that done is to go via your suppliers/fitters. I take it they were supplied by a reputable company and were for the UK market (some cheaper tyres have been imported into the UK and were not meant for this country), so check the rating and manufacturing codes.
However, if both tyres have worn on the inside, it may be that your front tracking is out, sounds like you have too much toe in in your settings if both have worn in this way. Driving over obstacles like speed humps and sleeping policemen can put the settings out, especially if you straddle these (you should drive straight over them, in the middle, alternating between searside and offside wheels and at a S...L...O...W speed. Suspension bushes can also fail because of these raodside hazards (bollocks to traffic calming :angry:). Get the tracking/wheel alignment checked before fitting new tyres - a 4 wheel alignment would be best.
Put your new tyres on the rear, not the front.
As for Dunlop Sport Maxx - had them factory fitted on my old GTI - did 15800 miles without any wet/dry issues and they had plenty tread left when I sold it. Better tyres out there, yes, but they ain't that bad.
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline ub7rm
« Reply #4 on: 26 May 2009, 17:12 »
However, if both tyres have worn on the inside, it may be that your front tracking is out, sounds like you have too much toe in in your settings if both have worn in this way. Driving over obstacles like speed humps and sleeping policemen can put the settings out, especially if you straddle these (you should drive straight over them, in the middle, alternating between searside and offside wheels and at a S...L...O...W speed. Suspension bushes can also fail because of these raodside hazards (nuts to traffic calming :angry:). Get the tracking/wheel alignment checked before fitting new tyres - a 4 wheel alignment would be best.
Cass
There are worse tyres I agree.  But I personally had to change my fronts as the inside edge wore away to nothing even though there was plenty tread on the rest of the tyre (and was in fact still legal) but I could see something was wrong.  I had the alignment checked and it was perfect.  Then I found the many people complaining of this issue with the same type of tyre.... doesn't take a genious to see what the problem is.
2020 BMW 128ti
Offline Davey
« Reply #5 on: 26 May 2009, 17:42 »
So, I've had the tracking checked and it's fine. The tyres were original fit Bridgestone Potenza Re050 225/40 R18 on Monza II's so definately not dodgy imports. Sounds from what's been said that others have seen similar problems on some other tyre makes so think I'll change the make when this lot have worn out.
Offline ub7rm
« Reply #6 on: 26 May 2009, 17:53 »
:shocked: Shytemax falsely accused (this time...) I've not heard about the issue with that tyre, AFAIK it was only the dunlops that suffered from this problem  :undecided:
2020 BMW 128ti
Offline R32UK
« Reply #7 on: 26 May 2009, 18:20 »
i had a similar problem with my sportmaxx too... now switched to Goodyears :grin:
Offline martininwillerby
  • Golf GTD DSG
« Reply #8 on: 26 May 2009, 20:08 »
Hi...
My 18" Bridgestone RE050's did this, But the 19" Sport Maxx was spot on.
My GTI was a June 05 birth and had Monza II's on.
Martin
Golf GTD DSG, RSN510, DAB, Bluetooth, Leather, 18" Charleston Shadows, Park Assist And In The Best Colour... White.
Martininwillerby
Offline TomB
« Reply #9 on: 27 May 2009, 02:48 »
Do you have these speed humps in your area?
They're everywhere in Northampton and they've cost me hundreds in uneven wear over the years!
When you say you're getting the alignment checked, is this a £20 laser job or a £100 digital alignment with printouts?
Tom
MK5 Golf GTI in Tornado Red
