Author Topic: whats this tube for?  (Read 1111 times)
Offline nikkyboy
« on: 26 May 2009, 12:49 »
Hi,
What's this tube for?  It pokes up, out of the driver side of the bulkhead. The pic below has been taken with big rubber air hose removed from the inlet manifold.  The cardboard hose on the right feeds (warm?) air into the bottom of the airbox.  Oh yeah, the cars an 8v digi.
Re: whats this tube for?
« Reply #1 on: 26 May 2009, 13:18 »
fuel tank breather perhaps?  not seen one from there on a MK2 begfore. is it a UK model?
get under car and you should see it poke out bottom of chassis leg with the 2 fuel lines, follow it back
Offline nikkyboy
« Reply #2 on: 26 May 2009, 15:07 »
Yeah it is a UK model.  Right ho, I'll go and see where it goes  :smiley:
Offline nikkyboy
« Reply #3 on: 26 May 2009, 15:41 »
It goes back with the fuel lines to the fuel tank. When I looked under the circular lift pump cover, in the boot, I found the other end, not connected to anything.  It stank of petrol so I'm guessing you're right, rubjohnny.
