Author Topic: knocking noise (clutch depress)  (Read 1792 times)
Offline luked
« on: 25 May 2009, 18:27 »
Its for my MK2 Golf gti 16v 1987
Basically i have noticed a knocking noise when i begin to release the clutch to pull off. Its like a weird 2 knock/cranking noise.
Doesnt do it straight away usually, but after 10mins of driving it starts to do it everytime i pull off and release the clutch pedal, from traffic lights and so on.
Its kinda been doing it since the day i purchased the car, but then weirdly stopped when handbrake cable was changed. now its back again, and worse than ever. not sure if the handbrake issue is a coincedence, but thought ild say.
Any ideas what the problem is? and needs to be changed?
Cheers! much appreciated!  :wink:
Offline sidecarphil
Re: knocking noise (clutch depress)
« Reply #1 on: 25 May 2009, 20:23 »
i had a "double" cluck on my car before i changed my suspension
couldnt find it for the life of me
turned out the 3 ball joint bolts were loose
Offline danny_p
« Reply #2 on: 25 May 2009, 20:41 »
frount mount is allways a favoret for pulling away cluncks
all the VW's have gone bar 1.
Offline luked
« Reply #3 on: 25 May 2009, 22:39 »
front mount?? the noise does seem to be coming from the front passenger side (left) of the car.
if its the front mount, is this a big job?
Is there any other tell tail signs i should be looking out for? or probably just the case of paying £££ at a garage to find problem  :sad:
Someone else has suggesed it could be the clutch release bearing?
Offline Dan34
  • VTEC Powerzzzz
« Reply #4 on: 25 May 2009, 22:42 »
i had a similiar clunk, was a wishbone ball joint not expensive to replace really
Dan
Offline luked
« Reply #5 on: 25 May 2009, 22:49 »
Dan
ahh wicked. and that clunk noise was only apparent when pulling away from stationary? cheers  :wink:
Offline Dan34
  • VTEC Powerzzzz
« Reply #6 on: 26 May 2009, 15:19 »
Dan
yeah only when pulling away  :smiley:
Dan
