Author Topic: Mk3 windows !!  (Read 2559 times)
Offline Vigilante
Mk3 windows !!
« on: 25 May 2009, 17:54 »
What is it with mk3 electric windows? I looked at 2 this weekend, an 'R' reg and a 'P' reg......both had window problems. Is it a common fault with mk3's. And is the doorcard easy to get off to fiddle with the carrier, motor etc?
                         Also, the 'P' reg I looked at didn't have remote locking, or so the seller said......but the key was a VW item with a button in the middle. Do they all have remote locking, and is it an easy job to get it working if it's gone out of synch? My Mondeo did and it was a 2 minute job to get it working again..... :cool:
Offline eightyeightmph
Re: Mk3 windows !!
« Reply #1 on: 25 May 2009, 18:00 »
No idea on central looking, mines a N reg GTi & has central locking, so I'd imagine if they were GTi's they should have it, not neccessarily remote thoughm, depends on what alarm it's had fitted.
Window regulators are a common fault in MK3's, easy enough to fix/replace though, about £15-£30 from scrappies & 5 mins to change, door card is two screws then pops off.
2016 GOLF GTD
Offline operaghost
Re: Mk3 windows !!
« Reply #2 on: 25 May 2009, 18:33 »
Re the remote central locking; the button in the middle of the key may have been for a 'torch' built into the key.  Should be able to see a small glass 'bubble' or 'window' on the key.  Mine has the same thing, it's a '94 GL.
Remote central locking kits easy enough to get on Ebay, and relatively easy/cheap to fit.
Offline christomk3gti
Re: Mk3 windows !!
« Reply #3 on: 25 May 2009, 19:30 »
Yeah there a nightmare the windows.... i got a p reg 5 door gti, i had a problem with the passenger side rear window, the motor was fine, at some point it had maybe jammed, and the previous owner managed to open it but had nackered the housing that the window slots into... which is only a plastic overmould with metal insert which the motor cable is connected to that moves the window up and down.... anyway I cut down a nylon block and bolted it to the housing to repair it myself, works fine and never had any other probs with it... i do have a problem with my drivers side on now and again, the button on the door doesnt always seem to work, you got to mess about with it and it eventually works. could be some crap in it maybe... just need time to check it,,, the door cards are easy enough to take off tho.. hope this helps.
Black 8v GTI............. Whats a Waffle Valve?
Christo77
Re: Mk3 windows !!
« Reply #4 on: 25 May 2009, 19:47 »
Can look at another one if you like!  :laugh:  Know what you mean though..Up until a month or so ago i thought i was one of the few Mk3 owners on here with all electrics working..Fat chance now..Yep P reg and 2 windows have packed up!  Using the passenger side at mo and what's the bet that'll pack up as well!
Not sure what the answers are yet, only that my rear offside window dropped into the door and my drivers window has stuck closed.
Offline MK3GTI_16Valve
Re: Mk3 windows !!
« Reply #5 on: 25 May 2009, 19:58 »
I need a regulator and motor from the rear right door in my valver. Cant get any from the scrappies here and no luck on ebay, have been looking for a while. Have an add in the wanted section but no luck yet. Any ideas where I can get one reasonable? Summer is here and It would be nice to have it sorted
Re: Mk3 windows !!
« Reply #6 on: 25 May 2009, 20:10 »
Christo77, You have the same problem as mine then, the cable that sits in the housing for the window has come out, probably broken some of the plastic overmould, That is what i modified with the nylon block and a bolt to fix mine :) works fan bluddy tastic :-) ohh and i also got 2 full elecy window motor complete for either side of the front driver and pass... :-) I also heard there quite expensive :-) got mine given by my mate who sold his mk3 :-)
Christo77
Re: Mk3 windows !!
« Reply #7 on: 25 May 2009, 21:47 »
Ah..yep sounds like it..i somehow managed to wedge it closed for the time being but did notice the mechanism would pull the window down but not bring it up at all.
Thanks for the info anyway..i'll have a look at that one first.
Offline paddy_coyle
Re: Mk3 windows !!
« Reply #8 on: 25 May 2009, 21:57 »
What if the car doesnt have central locking, are this kits still easy to install?
Offline Vigilante
Re: Mk3 windows !!
« Reply #9 on: 25 May 2009, 22:19 »
Thanks guys  :smiley: I guess it isn't all that serious then........bit of a pain tho.What happened to that good 'ol VW quality build that keeps their secondhand prices high.....?? :lipsrsealed:
