Author Topic: changed ht leads and now wont start  (Read 1306 times)
Offline phildaint
« on: 25 May 2009, 16:10 »
ok the mk3 1.4 was misfireing so i changed the plugs, coil, dizzy cap and rotor arm and it started though was still misfireing.
iv now changed the ht leads and the car wont start, the plugs are all sparking and am really confused, any ideas as to what it could be?
Offline Bjork
Re: changed ht leads and now wont start
« Reply #1 on: 25 May 2009, 16:58 »
You put them on in the order you took them off?
Could be knackered leads straight out the box........it happens.
Offline phildaint
« Reply #2 on: 25 May 2009, 17:16 »
yea same order, thats a bit of a bummer. might put the old ones back on and see if it starts and replace the leads one by one, its started raining now though :(
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
« Reply #3 on: 26 May 2009, 18:28 »
did you do them one at a time?
and make sure they are fully connected
Offline perd999
« Reply #4 on: 28 May 2009, 15:27 »
best to work back and put all the old parts on starting with the leads....then next id try the coil etc, hope it gets sorted
Offline euro dave
« Reply #5 on: 28 May 2009, 15:42 »
did you put the sensors back on / take any off?  I did this on my 8v and was confused when it wouldn't start :angry:
double check they're back on in the right order, that's the best call.
