Author Topic: any ideas?  (Read 1655 times)
Offline carlos85
any ideas?
« on: 25 May 2009, 02:04 »
As i'm trying to put my car back to how it should be i keep finding cables etc not plugged in, so i need soome help with where they go to.
This is coming off the inlet
This is coming out the bulkhead head
Also there is a flat earth like cable coming from the bottom of the coilpack, but it's doing nothing
Re: any ideas?
« Reply #1 on: 26 May 2009, 10:35 »
1. should go to back of the clocks if its a GTI, runs the mpg gauge on the mfa
2. heated washer jets I beleive, not the end of the world
3. runs to an earth plate on the back of the head somewhere :)
Offline carlos85
Re: any ideas?
« Reply #2 on: 26 May 2009, 12:41 »
so does that mean my clocks would be two plugs not one?
Re: any ideas?
« Reply #3 on: 26 May 2009, 13:14 »
that is determined by the age of car. if hazard switch on column its a later CE2 electrics with single plug clocks, if on dash its early CE1 car with 2 plug clocks.
Offline carlos85
Re: any ideas?
« Reply #4 on: 26 May 2009, 14:33 »
it's on the column as the fusebox is the CE2 set-up
Offline carlos85
Re: any ideas?
« Reply #5 on: 26 May 2009, 17:11 »
another pipe found on the TB
Re: any ideas?
« Reply #6 on: 26 May 2009, 17:57 »
that is for the airbox warm air feed pipe, if its got a k&n then it can be capped off.  I just get a new pipe and run it from the nipple direct to the fpr.  also check round the back, there should be another blanked off vac pipe back there.
Offline carlos85
Re: any ideas?
« Reply #7 on: 26 May 2009, 19:37 »
i thought the green pipe was for the air box?
Re: any ideas?
« Reply #8 on: 27 May 2009, 07:56 »
yeah, the warm air feed on the airbox ;)
Offline carlos85
Re: any ideas?
« Reply #9 on: 27 May 2009, 11:47 »
i was wondering what the small pipe on the TB is for as i took the pipe of the green plug  :laugh:
