Author Topic: help needed. clutch  (Read 1700 times)
Offline k5ne_p
help needed. clutch
« on: 24 May 2009, 20:58 »
riht my clutch is starting to slip.. my clutch pedal is knackered too but made a bodge up to last me. so need to know how much the single mass flywheel is? and clutch. and clutch master cylinder and clutch pedal and the clips.. can anyone help me on this with part numbers or relevant places to get these items from?
thank you.
Offline Rhyso
Re: help needed. clutch
« Reply #1 on: 24 May 2009, 21:00 »
in the time it took you to write that you could have searched and found this
http://www.golfgtiforum.co.uk/index.php?topic=87775.0
Offline k5ne_p
« Reply #2 on: 24 May 2009, 21:18 »
i have found that article..i just wanted help on the clutch master cylinder and pedal and clips. there the bits i needed help with. sorry for not being very clear..
Offline Rhyso
« Reply #3 on: 24 May 2009, 21:20 »
ah right got you - was a bit jumbled together!
GSF, Eurocarparts, TPS or dealers are your most likely sources
