Author Topic: compression/timming  (Read 2144 times)
Offline parrotveasey81
compression/timming
« on: 24 May 2009, 11:31 »
1.8 8v gti just replaced my head gasket and when doing so i found out its a tsr engine with a tsr202 cam with a standard pulley,thing is when i timed it up it ran good but was flat(i also fitted a 4 branch manifold at the same time)
when the timing is set to factory i get 12bar on all 4 but is flat
when i set the cam 1 tooth forward i get 14bar on all 4 and it goes better but you can only use half throttle as it misfires on full throttle
when i set the cam 2 teeth forward i get 16bar on all 4 and it sounds a lot better but wont rev over 4500rpm
the only thing that is different to before is the manifold so would this make that much difference that i would have to have it tuned again,also i have played with the dizzy timing as i was told that it would make a difference but all that does is make it pink even worse?????
drive it like u stole it,brake it then mod it
Re: compression/timming
« Reply #1 on: 24 May 2009, 18:18 »
anyone,rj.danny p would really like to get this sorted before end of Monday ready for work.
Offline danny_p
« Reply #2 on: 25 May 2009, 08:54 »
try retarding thr cam,     worth finding  out what a rsr 202 actualy is and how it should be timed.
knock it back a tooth if it runs it should be quite peacky then
all the VW's have gone bar 1.
« Reply #3 on: 25 May 2009, 10:54 »
I worked at Tsr for 4yrs, 202 or 203 cam is set as per standard however the dot on the back of the pulley needs to be lined up to the edge of the head and not the rocker cover.
A 202 is not that hot a profile by the way 268 / 272, a 203 is 286.
Hope this helps.
« Reply #4 on: 25 May 2009, 20:14 »
thanks,i timed it up as you said bit it is still flat,i runs fine and will rev out in gear with no misfire or pink,the temp sensor and maf are working and there is no vacuum leaks so what else could it be.
« Reply #5 on: 26 May 2009, 10:42 »
have you done the ign timing as per the digifant tuning guide?
« Reply #6 on: 26 May 2009, 18:37 »
rj no not at the mo as i have been looking for info on mfa's as mine works fine on normal mode but in secret mode it only shows this on p1 and p2
8888(just all lines that look like 8's)
123
7418
1325
3
955
i have only just got the mfa working as when i got it it did not work,when i took the lower dash off i found out that the wires were cut so all i done is join them back up(and yes i got the colours right)
if i cant get the mfa working is there any other way of doing the tuning???????
« Reply #7 on: 27 May 2009, 07:56 »
you dont have to use the MFA secret mode for tuning, just makes it a bit easier as you have a digital rev counter.  you can still use the normal rev counter ;)
« Reply #8 on: 27 May 2009, 18:28 »
sorted,i will get it tuned at the week end and see if that makes a difference
« Reply #9 on: 30 May 2009, 20:39 »
right done the tuning today and it runs a lot better(dizzy timing was a bit out)but it still flat after 3750rpm as if its not getting enough fuel and it wont go much over a ton ware as before it would go off the clock(120mph clocks)plus at a ton it use to pull realy good so these leads me to the next Question when you take the co reading do you do it with the temp sensor connected or not as the car runs better if i screw the screw on the maf all the way in.
also fitted my poly bushes today on the front(minus the inner anti roll bar ones)and its made the front end so much sharper,now the back end fills all sloppy so i will have to fit the poly rears soon.
