Author Topic: what the hell! mk2 caliper bolts.  (Read 2060 times)
Offline antogoof
  • bbm mk2 g60
« on: 23 May 2009, 21:59 »
tried today to get my caliper off and one of the allen bolts was rounded, i tried welding an allen key into it and then tried welding a bolt on to it and neither worked.
any ideas on how i can get it out? :angry:
mk2 bright blue met bits wanted in north west.
Offline Millyriot
Re: what the hell! mk2 caliper bolts.
« Reply #1 on: 23 May 2009, 23:24 »
same happened to me, i ended up cuttin the carrier with a grinder as i had a whole spare rear setup off a mk3 neways, failing that ur gonna need to find sumone with voodoo magic  :sad:, why couldnt they have used nice hex bolts  :cry:, sorry i cant be of help
Offline antogoof
  • bbm mk2 g60
« Reply #2 on: 24 May 2009, 00:29 »
i think im going to go for heat a big hammer and a vice grip and kick its arse!
Offline AudiA8Quattro
« Reply #3 on: 24 May 2009, 11:22 »
Go on ebay and search irwin extractors. Work everytime.
Offline antogoof
  • bbm mk2 g60
« Reply #4 on: 24 May 2009, 11:23 »
nice one buddy going now. :smiley: :smiley:
Offline antogoof
  • bbm mk2 g60
« Reply #5 on: 24 May 2009, 11:35 »
right had a look on ebay and i want to buy some i just dont know which? help!!!
Offline Ben Lessani
« Reply #6 on: 24 May 2009, 11:50 »
Just use a set of mole grips, whack it on the head a few times with a hammer, then grab it tight with vice grips and it will come straight off.
« Reply #7 on: 24 May 2009, 12:13 »
These will do the job
http://cgi.ebay.co.uk/Irwin-BOLT-GRIP-5pc-Bolt-Extractor-Expansion-Set-add-on_W0QQitemZ400049791912QQcmdZViewItemQQptZUK_Measuring_Tools_Levels?hash=item5d24d363a8&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
They are well worth the money, and a good addition to any tool set.
Offline Ben Lessani
« Reply #8 on: 24 May 2009, 12:27 »
Do you secretly work for Irwin? :grin:
« Reply #9 on: 24 May 2009, 12:40 »
No, i sell fish and chips  :laugh:
I've tried the grips method before on a mk3, it still wouldn't budge.
Mk3's also have loctite put on the threads, so they are real f**k*r to remove.
Those irwin extractors always work, without fail.
I usually don't bother even trying to remove the bolts with an allen key socket, they always round off.
I use the extractor to remove the bolts, then clean up the head and re-use them.
