Author Topic: How many miles it I run out of fuel  (Read 3529 times)
Offline jonesltd
  • MK7 R
« on: 23 May 2009, 19:53 »
Have a 2002 tdi and wouldnt mind knowing if I can get some software or anything for the car to tell me how many miles I have left until I run out of fuel rather than guessin? I know its simple...soon as lite comes on  - fuel the flippin car up - but sometimes not always that easy.... I know some golfs do it and my old Audi S3 did which was handy...Ta
If you cant find it......Grind it
Offline T_J_G
Re: How many miles it I run out of fuel
« Reply #1 on: 23 May 2009, 19:56 »
You can program the cluster to enable this feature. Read a few of the threads below with the name VAG TACHO in the titile and all will be revealed.
Offline jonesltd
  • MK7 R
« Reply #2 on: 23 May 2009, 20:23 »
How much that gonna set me back?
Offline T_J_G
« Reply #3 on: 23 May 2009, 21:32 »
Depends if you have the right clocks first. Do a bit of earching on here for Miles To Empty. All been covered before.
Offline Rhyso
« Reply #4 on: 23 May 2009, 21:38 »
on an 02 the clocks will be fine - both Bosch and VDO clocks can have MTE enabled  :nerd:
Offline mikemk4gti
« Reply #5 on: 23 May 2009, 22:00 »
anyone got a how to for this? I have vag commander that can read and write eeprom but I don't know what I should be changing??
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline Ridg
  • TDI - Soot Happens!
« Reply #6 on: 24 May 2009, 12:11 »
even with miles till empty enabled the car is still going to guess as it works it out using the average MPG, which can so easily change.
Given that the light comes on when you've got 8l left (can be changed, and it's more for the V6) you'll have about 1 1/2 gallons of fuel left.  You need to keep in mind, that that last 8l is going to contain all the dregs at the bottom of the tank (which the filter will filter out) but a diesel engine isn't the same as a petrol (obvioulsy) as in if you run out you can't just walk to the petrol station and put more in the tank, and empty diesel engine needs to be purged of any air that's been drawn in when the tank went dry.
Offline jonnyturbo
« Reply #7 on: 24 May 2009, 18:41 »
Yep i have just had miles to emtpy activated on mine and its well worth it IMO
Offline Rhyso
« Reply #8 on: 24 May 2009, 20:37 »
whilst its a nice feature you got to ask the question - what's wrong with looking at the fuel gauge?  :huh:
and before anyone says - i enabled it cos i could  :tongue:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #9 on: 24 May 2009, 21:16 »
ha ha ha ha Erm shall i mention the auto dimming mirror   :lipsrsealed: :lipsrsealed:
