Author Topic: Lowering  (Read 4300 times)
Offline jonesltd
  • MK7 R
Lowering
« on: 23 May 2009, 19:46 »
I am very new to this but I have a 2002 mark 4 tdi and want to get it lowered. Can I just lower it without changing anything else ie shocks etc..
Ended up on dreaded ebay as I cant afford brand new ones so what about this one 110392823224
Hope you can help
Thank you
If you cant find it......Grind it
Offline T_J_G
Re: Lowering
« Reply #1 on: 23 May 2009, 19:54 »
You can use just springs or springs and shocks or coilovers.
All have their advantages. How much drop you want?
Those on eBay don't tell you the make, model or definite drop and seems a bit sketchy. You can pick decent brand new springs up for £100ish.
http://www.golfgtiforum.co.uk/index.php?topic=89176.0
« Last Edit: 23 May 2009, 19:56 by T_J_G »
Offline jonesltd
  • MK7 R
Re: Lowering
« Reply #2 on: 23 May 2009, 20:06 »
It says it goes to 35-40? I have no idea which is lower 35 or 40 I know that sounds stupid. I just want my car to look lower...Have asked him a few questions so waiting for a reply ie make, miles its done etc..
Offline Rhyso
Re: Lowering
« Reply #3 on: 23 May 2009, 20:12 »
higher the number the lower you go  :smiley:
Offline jonesltd
  • MK7 R
Re: Lowering
« Reply #4 on: 23 May 2009, 20:22 »
Having a proper bad day but the higher the number the lower you go - just dont make sense? Normally the lower the number the lower you go as you are closer to the ground being zero?
Also whats the normal mm ppl go for? 35mm? Dont want any problems later having just read a thread abt coils etc..
Offline Rhyso
Re: Lowering
« Reply #5 on: 23 May 2009, 20:29 »
it has nothing to do as to how far from the ground you are.  Golfs sit at specific heights based on what springs they are fitted with; to lower them you fit lowering springs - the higher the number the more the car is lowered  :nerd:
30-45mm is normal for most people as it will help retain most of the ride comfort yet help with the handling
Offline northeast_gti-t
  • "1.8T AGU"
Re: Lowering
« Reply #6 on: 23 May 2009, 22:59 »
and just to add any lower than 50mm and the front arb rubs on the driveshaft  :nerd:
2000 Mkiv GTi 1.8T AGU
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Lowering
« Reply #7 on: 24 May 2009, 08:52 »
It means (minus) 30mm OFF the standard ride height. ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline alex160
Re: Lowering
« Reply #8 on: 24 May 2009, 10:35 »
i got a brand new set of lowering springs off a company called "performance 3000" near me, cost £50 for the springs, think there g-maxx, there very good, nice and stiff but still give a good comfortable ride, and lower 35mm like they say. think they sell them on ebay  :smiley:
2001 Golf GT TDi  150bhp/ 250 ftIb torque  *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
Offline Ridg
  • TDI - Soot Happens!
Re: Lowering
« Reply #9 on: 24 May 2009, 11:57 »
all comes down to how low you want to go, springs will give you a fixed drop, where as coilovers give you an adjustable option, this means you can then have the rear lower than the front etc.
the think to keep in mind with just changing the springs is that, these springs aren't going to be designed to work with the dampeners already on the car (eibach pro sport are meant work well with VW Sport OEM dampeners though) as a result changing the springs can result in extra wear on the dampeners and ultimately in them failing prematurely, on the other hand coilovers (genuine coilovers (which technically you can't get for a MK4 given that the rear suspension is trailing beam)) are matched as in the spring is matched to work with the dampening that the spring "coils over" this results in a more predictable spring rate /dampening etc, and for the same travel should be smoother than shocks and springs (more progressive).  As previously said coilovers also let you adjust the suspension as you wish (which in motorsport would be tweaking for different tracks) but in the modding scene it often means just getting the ride height and walking away (a waste of coil overs IMO) but often the only way to achieve 45mm + drops
also keep in mind like everything in life, the amount you spend with affect the quality of what you get, so £150 coilovers aren't going to be as good as £1000 one's however if you're looking to purely change the ride height they will both do the job.
I'm personally running eibach pro sport springs and dampeners (which are "matched") as i only wanted a 20-30mm drop to produce a similar ride height to the anniversary, he eibach setup also offers probably the best compromise between ride comfort and handling (for springs)
if you're thinking of going lower, then look at steve_pd's pics as he's on about 45-50mm drop (coilovers)
more info on lowering can be found
http://forums.vwvortex.com/zerothread?id=1835863&postid=18980504#18980504
