Author Topic: delock kit  (Read 3668 times)
Offline golfgar
  • Audi A6 estate/subaru wagon
delock kit
« on: 23 May 2009, 17:14 »
bought some 2nd hand blanks not to sure how to fit anybody know how its done???
« Last Edit: 23 May 2009, 21:43 by golfgar »
Offline Grand Master Patch
Re: door lock blankes
« Reply #1 on: 23 May 2009, 18:43 »
Search delock :wink:
Offline golfgar
Re: delock kit
« Reply #2 on: 23 May 2009, 19:13 »
cheers mate,sorted now apart from i didnt get any little circle metal plates anyone know where i can get any??
Offline K666PDP
Re: delock kit
« Reply #3 on: 23 May 2009, 19:30 »
like needles in a haystack mate!!!, very odd size but once blanks fitted (glued in!)very difficult to ever revert back to fitting original lock!! so prob best to leave as it is as very unlikely a thief will attempt to break in via the lock with a delock kit on!!.........btw i have delocked both front doors using the metal disc
Offline golfgar
« Reply #4 on: 23 May 2009, 21:42 »
will put them on without the disc,like you said easier to change back. :smug:
Offline northeast_gti-t
  • "1.8T AGU"
Re: delock kit
« Reply #5 on: 23 May 2009, 23:26 »
dealers  :wink: ask for 'metal disc' iirc its not listed on etka depends on the parts dept knowledge to varies from dealer to dealer i usually find  :wink: if not a 5p piece is a near fit
2000 Mkiv GTi 1.8T AGU
Offline Steve_PD
Re: delock kit
« Reply #6 on: 23 May 2009, 23:35 »
Am not sure if the disc is need because if the replacement barrel is in place how are you meant to get it out with the door shut  :undecided:
Offline K666PDP
Re: delock kit
« Reply #7 on: 24 May 2009, 08:18 »
prob like if u were breaking into a normal lock with the standard lock taken out all u need is a flat headed screw driver to put inside the lock to open it!! after uve smashed thru the blanking plate of the delock kit!!, the metal disc prevents access to the lock itself making it impossible to get to the internal lock to open the doors ect!
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
Re: delock kit
« Reply #8 on: 24 May 2009, 08:23 »
i just happen to have loads of these... as i work for a sign company that has a laser... i dropped one in my door so i had to cut loads spare so i have quite a few... there is no point delocking if your not gonna put these in it will take the average thieving scumbag mins to enter your pride and joy and cause damage and pain to you and your wallet.
if anyone needs any of these PM me
...Burn Rubber...Not Your Clutch...
Offline richw911
Re: delock kit
« Reply #9 on: 24 May 2009, 09:56 »
As said and as sambo pointed out a while ago without the metel disc it is VERY easy to break into you really need to fit them  :wink:
