Author Topic: Rear disks  (Read 1071 times)
Offline Daston
Rear disks
« on: 22 May 2009, 18:38 »
Hi guys,
Got my rear wheel off to give it a bit of a clean (19 years worth of brake dust), I noticed the rear disk looks really thin. Now this is the first car I have worked on that is A) So old and B) Front Wheel Drive so it could be possible the disks are supose to look like this.
Offline Daston
Re: Rear disks
« Reply #1 on: 22 May 2009, 18:57 »
Ahhh some pic's might have helped
Offline Ben Lessani
Re: Rear disks
« Reply #2 on: 22 May 2009, 19:53 »
Disks shouldn't look rusty or scored like that - looks like your calliper isn't even working.
The thickness is a judgement call, each manufacturer has their own figure. But you can gauge it, if the lip at the edge of the disk is quite deep - its time for replacement.
Check out how worn the pads are! Remember, replacing the disks, means rear bearings too (not neccessarily new, but the shells need swapping over).
Offline Daston
Re: Rear disks
« Reply #3 on: 22 May 2009, 20:07 »
cheers the pads are full. Its rusty as its been sat still for nealy 4 weeks now.
Offline Ben Lessani
Re: Rear disks
« Reply #4 on: 22 May 2009, 20:20 »
Going off the pictures, and how close the calliper is to the disc - they don't look particulary thick
Offline Daston
Re: Rear disks
« Reply #5 on: 22 May 2009, 21:43 »
hmm good point, I would say they have 5mm left on them. Going to see how bad the front ones are tomorrow and I may end up getting a full set just to be sure.
Offline jezza16v
Re: Rear disks
« Reply #6 on: 22 May 2009, 22:25 »
They look fine to me, the rear discs don't have much to do anyway. They just need to be used to clean them off, you could change them but you'll probably not notice any improvement at all in the braking as they're  pressure limited anyway. The front discs do nearly all the work.
Offline sidecarphil
Re: Rear disks
« Reply #7 on: 23 May 2009, 06:27 »
they look ok to me  :wink: :wink:
better than mine , so if you do change them , give me first dibs on the old ones  :grin: :grin:
Offline neils
Re: Rear disks
« Reply #8 on: 23 May 2009, 10:33 »
