Author Topic: kko3s  (Read 873 times)
Offline 20v
kko3s
« on: 22 May 2009, 02:11 »
if  i have a agu will it make a big difference if i use the 180bhp injectors rather than the 150bhp bein as im fittin a ko3s  are they worth the extra money will they make a noticeable gain
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: kko3s
« Reply #1 on: 22 May 2009, 05:50 »
they won't fit. Speak to R-Tech, they will tell you they aren't needed
You can't just throw in bigger injectors and run with them anyways, they will need mapping to suit
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: kko3s
« Reply #2 on: 22 May 2009, 13:08 »
The standard injectors will be good enough mate, as wazzer mentioned you will just need a remap if fitting a K03's so that your air/fuel mixture will be correct.
Only time you'll need to change injectors is if they fail or you want power around 300bhp and then its a case of upgrading fuel pump & Fpr.
Use the search option and they'll be loads of info on K03s upgrades
