Author Topic: What do you think?  (Read 1327 times)
Offline Steve_PD
Re: What do you think?
« Reply #1 on: 21 May 2009, 23:24 »
If your going to run 20mm make sure they're hub centric ones, which these are not. Also get the ones which the adapter bolts to the hub and then the wheel bolts to the adapter, look for H&R and FK ones they're a bit more expensive but worth the extra :afro:
Offline jake
« Reply #2 on: 21 May 2009, 23:29 »
thanks for the advice steve!i think i will go with the FK ones
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 22 May 2009, 06:27 »
better choice tbh  :wink: those e-bay ones are'nt worth the money like steve says there not hubcentric which is preferable and from what i have heard those kits aren't alloy at all and they are heavier best steer clear and buy a reputable named kit imo  :wink:
2000 Mkiv GTi 1.8T AGU
