Author Topic: Car Won't Start, Any Ideas?  (Read 869 times)
Offline Negative Creep
« on: 20 May 2009, 19:07 »
My Golf was always a bit slow to turn over but fired up every time. However the other night I got in and nothing. The engine won't turn at all and the starter doesn't even click. What's more, every time you turn they key into the 'start' position, the dash lights go out, the clock resets and the warning lights no longer come on! Everything else electrical works fine however.
I've had it to my local garage but they cannot work out the fault. The battery is new, there is power coming from the ignition switch and to the starter. Did try a bump start and the engine turned over very slowly, but I ran out of road so couldn't try it again. Any ideas before I get it towed to a specialist and pray they find the fault quickly?
1987 Golf GTi 16v
1975 Datsun 120Y
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
Re: Car Won't Start, Any Ideas?
« Reply #1 on: 20 May 2009, 19:12 »
Hi mate! Sounds like a bad earth? Or faulty starter. Or, more than likely a bad earth for the starter, which would possibly be the one off the 'box, going to the passenger side chassis leg. Check that hasn't snapped mate.
Offline Ben Lessani
« Reply #2 on: 20 May 2009, 19:32 »
Starter bell housing bush
Offline aaron1980
« Reply #3 on: 20 May 2009, 23:08 »
sounds like you starters dead! :cry:
Offline dirtydub
« Reply #4 on: 21 May 2009, 10:05 »
i had exactly the same problem
cleaned up the earths and its hasnt happened since  :wink:
Rich
'86 golf gti 8v k-jet project up and running :)
