Author Topic: Digifiz dash  (Read 7082 times)
Offline sidecarphil
Re: Digifiz dash
« Reply #10 on: 22 May 2009, 11:52 »
you need:
loom from unit to fusebox, either easy if 90spec, or hard if pre-90! Follow the plugs from it as far as you can.
hangers from inside the dash
speedo sensor, though a mk3 one will also work. may as well use his though as he'll need a normal speedo cable!
loom from speedo sensor to dash, but this might be a fair bit of work. not hard to make your own loom up using mk3 speedo sensor plug
so sire Jonny of Rub  :grin:
when you say "fair bit of work" are you talking a days rewiring or is it just follow the wires and unplug
i'm guessing his car is a per 90 like mine so is removing the wiring inside the car REALLY difficult ??
do you have a wiring diagram i could beg from you ???
Re: Digifiz dash
« Reply #11 on: 22 May 2009, 14:42 »
main issue is the speedo loom will be integrated into the engine or lighting loom, so prob best to leave his alone and make your own one up see. dash wiring is dead easy if its 90spec as it runs from clocks to dash and is completly seperate to any of the other looms.
I have mk2 and mk3 diagrams, these should be enough to get it sorted, im 90% sure the speedo sensor is wired in as per mk3 :)
Offline sidecarphil
Re: Digifiz dash
« Reply #12 on: 04 September 2009, 17:21 »
in fitted and looking retro as foooooooooook  :laugh: :laugh: :laugh:
how do i get the INSP lamp out ?????
Offline dan_apps
  • too low for british roads!
Re: Digifiz dash
« Reply #13 on: 04 September 2009, 17:44 »
looks the shizz! :cool:
Offline sidecarphil
Re: Digifiz dash
« Reply #14 on: 04 September 2009, 17:52 »
i need the wiring diagram for the clock adjuster , the wires were missing
and also my MPG doesnt work in this set of clocks , did on the old clocks , and the pipe is on for the vacuum pipe  :undecided: :undecided:
Offline Jay
  • balding fat cvnt
Re: Digifiz dash
« Reply #15 on: 04 September 2009, 21:37 »
I agree with Conker, this is the only 'scene' item i'd really enjoy having. :cool:
Offline sidecarphil
Re: Digifiz dash
« Reply #16 on: 04 September 2009, 21:45 »
well for the right money and a swap of a loom i may sell it  :wink: :wink: :wink:
or if the car fails its dutch MOT the whole lot will be for sale
got my eye on a loverly G60 ED1 but he wants €4500 for it  :shocked: :shocked: :shocked:
Offline purplebug
Re: Digifiz dash
« Reply #17 on: 06 September 2009, 20:48 »
There is a "unit only" one for sale on scottishvag for £300  :shocked:
Offline sidecarphil
Re: Digifiz dash
« Reply #18 on: 06 September 2009, 22:41 »
foooooookin hell !!!!!!
i like it but i have a few minor issues with it !!!! the clock resets to 01:00 every time the ign is off and the lighting system doesnt work propperly , i assume it will dim down when i put my lights on as during the normal daylight it is back light
Rubjonny , do you have a wiring Scheme for the Digifiz dash ????
Offline Ben Lessani
Re: Digifiz dash
« Reply #19 on: 07 September 2009, 08:57 »
Surely those two hiccups should be easy to remedy? Sounds like your using an IGN live, not constant live.
