Author Topic: Lowering.. What springs??  (Read 2429 times)
Offline scottyboy08
  • mk4 anni rep....1.4 really :P
Re: Lowering.. What springs??
« Reply #10 on: 21 May 2009, 19:42 »
I have just been working up near there at a little place called llanefyyd near rhyl....I am from hull though haha thought I would just let you know
Offline jake
« Reply #11 on: 21 May 2009, 20:35 »
mate if your after springs i got a set of rear 50mm weitec springs for sale!
One of the best springs you can buy! only 45 quid!!
Offline jeynesey
  • Non VW but still VAG
« Reply #12 on: 21 May 2009, 21:33 »
I did mine recently, 35mm no probs. jamex set off ebay I paid £60 then a few days later jamie16v got them for £52! delivered.
http://www.golfgtiforum.co.uk/index.php?topic=116750.0
and
http://www.golfgtiforum.co.uk/index.php?topic=116826.msg1025378#msg1025378
yea i've orderd those ones for £52. where in north wales are you from mate?
yep, i`ve fitted them now too, did exactly what it said on the box. well worth the price.. if i could have afforded uprated dampers too i would have done that but cash wernt permitting at the time.. :tongue:
bargain in my opinion!. i doubt you`ll find springs cheaper.
Did you fit them yourself mate?? easy job??
jamie16v
« Reply #13 on: 21 May 2009, 21:42 »
easiest suspension job i have ever done to be honest..
you need a 7mm allen key ( which i didnt have) and a suitible swan neck spanner (which i didnt bother using).
i just used the impact wrench to undo the front top nuts and undid the bottom pinch bolt with the conventional ring spanner and breaker bar.
 the rears were simple as abc.. just undid the bottom bolts on both sides whilst supporting the weight of the axle with a jack (makes it easy to remove the bolts ) once both bolts are out, remove the jack and the axle will drop and you can remove the springs..
