Author Topic: What temp does the fan kick in at on mk3 16v??  (Read 1928 times)
Offline imran4
« on: 20 May 2009, 14:07 »
Can anyone help with this topic please?
http://www.golfgtiforum.co.uk/index.php?topic=117277.0
Hi
Does anyone know at what temp does the fan kick in at on a golf gti mk3 please?
cheers
Re: What temp does the fan kick in at on mk3 16v??
« Reply #1 on: 20 May 2009, 14:28 »
1st speed 95-84, 2nd speed 102-91
my guess thats switch on-switch off temperature :)
Offline imran4
« Reply #2 on: 20 May 2009, 14:36 »
cheers. just following my other post under mk3, and looks like an airlock as pipes are really stiff...gonna try to get rid of air, then look at thermostat
Offline imran4
« Reply #3 on: 20 May 2009, 16:07 »
Fan is kicking in now at 110, I think was an airlock plus it kicks in a little later than expected.
Thanks guys
« Reply #4 on: 20 May 2009, 16:28 »
hmm, maybe the low speed setting on fan or switch has packed in?
if you disconnect the fan switch if it has 3 pins its a dual speed setup. bridge the red wire to 1 pin, then the other and it should come on slow & fast. if so the switch may be at fault, or you have poor coolant circulation thru the rad.  if it doesnt come on slow or fast, jump the fan direct from the battery. if it still doesnt come on slow or fast then the fan itself is buggered.
Offline imran4
« Reply #5 on: 20 May 2009, 16:35 »
Quite possibly...
...might try that some other time. Just packed the tools away and cleaned up :undecided:
