Author Topic: N/S XENON HEADLIGHT NOT WORKING :s  (Read 1881 times)
Offline m4ahn
« on: 20 May 2009, 10:46 »
hey guys i recently bought new angel eyes headlights for my golf and then bought 5000k hid kit. i installed the headlights then a week after i got the hid kit and installed them. all was working fine until about a week ago, my n/s xenon (hid xenon) dipped beam dosent work but the other side does..... and when i turn the light completely off and then back on they both work then? and some times they both come on straight away it is just 9/10 times the n/s light dosent work? i have taken the lights back out since and taped eveything up and made sure all was good but still does it? ay ideas please lads? thanks
Offline navmk4gti
Re: N/S XENON HEADLIGHT NOT WORKING :s
« Reply #1 on: 20 May 2009, 11:00 »
check the fuse... or for loose wiring sounds more like a loose connection somewhere..  :smiley:
Offline old_n07
« Reply #2 on: 20 May 2009, 11:20 »
Or it could be a faulty ballast, swap them over and see if the fault follows the ballasts
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline player.777
« Reply #3 on: 20 May 2009, 12:34 »
mine occasionally do the same- one trick which seems to work (no idea why) is if I turn on the side lights first, for about 10secs, then the dipped headlights, both work fine.  Also, when I took the bumper off last, I played around/untangled with the wiring and that seemed to do the trick as well.
Offline m4ahn
« Reply #4 on: 21 May 2009, 08:08 »
hmmm i will have a go at it tonigt but is awkward wen driving at night and only one dipped beam :( i am taking bumper of again tonight to see but i think it is only maybe a ballast or a bulb perhaps i will swap them around tonight and see, only thing is i have secaflexed the ballasts down so they were secure and free from water lol thanks guys :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 21 May 2009, 10:21 »
ballast keeps tripping out mate, send it back and get a new one, it's the only solution
Offline m4ahn
« Reply #6 on: 21 May 2009, 21:07 »
hey again after taking my headlights out again....... *sigh* it is the ballast pack that is faulty so i am getting a new sent out in the next day or two but now another problem has occured, i now have no headlights full stop now :S ??? i have checked the fuses in the drivers compartment at the end of the dash and all is well and no blown fuses but still have no lights (only the o/s light works as the n/s ballast is down) what so ever now can anyone please help me ? thanks anthony
Offline m4ahn
« Reply #7 on: 21 May 2009, 21:32 »
help me please ><
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 22 May 2009, 05:57 »
You need to start by using a multi meter to check if you are getting 12v to the plug for the headlight when they are switched on.
Offline m4ahn
« Reply #9 on: 22 May 2009, 07:58 »
hey wazzer thanks for the help also mate you a star but listen to this for a tale, i have just got up this morning drove to work and put my headlights on and they are working again :S (the o/s headlight ofcourse as the n/s headlight ballast is down) i have tried flicked them on and off in different sequence and they work fine hmmmm confused now what should i do? thanks again anthony
