Author Topic: Clicking noise  (Read 1656 times)
Offline Andyfloss03
  • "You Muggin Me Off Infront Of My Pals?"
Clicking noise
« on: 20 May 2009, 09:41 »
when you pull forwards it makes a few clicks then stops.... then again when you brake or go into reverse...?!
is this like lower arm or cv or bushes or something...its right hand side
Offline Car nut
  • The Black Beaver
Re: Clicking noise
« Reply #1 on: 20 May 2009, 09:45 »
I'd get it to a local garage up on a ramp and let a pro take a look.
Get a price for the work, then get it done if you want or do it yourself if able ;)
Daily Hack - '53 - AUM - GTI T  "The Black Beaver" :wink:
Playing with a  Black Beaver   :grin:  -  Updated  -  Wed, Jul 8 2009 4:56 PM
BMW E39 M5 Individual '02- 400bhp - Sold but not forgotten !
Jaguar E Type S1 FHC 3.8 - Project car on my website in Profile
Offline dai-cymru
  • 1989 MK2 16V
Re: Clicking noise
« Reply #2 on: 20 May 2009, 09:51 »
sounds like the CV or something as silly as something stuck in the tyre
Offline Andyfloss03
Re: Clicking noise
« Reply #3 on: 20 May 2009, 09:55 »
get it when you turn right... deffo a proper click.. like something moving.... when your going its fine.. just a sudden change in direction or something causes it to click.
deffo not summat in the tyre :)
Offline Steve_PD
Re: Clicking noise
« Reply #4 on: 20 May 2009, 17:24 »
Wishbone bushes   :undecided: mine done this when you pulled off or stopped, changed the bushes last weekend and they where fooked, all good now  :smiley:
Offline 20v
Re: Clicking noise
« Reply #5 on: 20 May 2009, 18:53 »
cv joint mate mine is also doin this
Offline golfgtidan
Re: Clicking noise
« Reply #6 on: 20 May 2009, 21:00 »
could be brake pads in the caliper, remove them clean them up and use some copper grease when refitting, eliminates something easy before getting it garaged!
1999 1.8t : Winter Pack : Kamei Mesh Grille : Forge 007p D/V : Carbonio Cold Air Intake : R-tech remap : 18" Toora Alloys : -30mm Eibach Springs : Smoked Side Repeaters : Hella Magic Colours Rear Lights : Hella Black Headlights : "hid" Headlight Conversion : Aero Blades Front & Rear: ECS KVW100 Window Control Module : Milltek resonated cat back
Offline Andyfloss03
Re: Clicking noise
« Reply #7 on: 21 May 2009, 08:38 »
o its not sounding good ha
Offline sax4u
Re: Clicking noise
« Reply #8 on: 21 May 2009, 23:55 »
I have the same problem with that clicking noise, was told its most likely to be the cv joint too, but not had the time to get it done yet. I will be getting the wheel bearing done at the same time, cos its starting to annoy me! Most be a common thing on Golfs!  :shocked:
