Author Topic: Heated seats.  (Read 2137 times)
Offline manny2k80uk
Heated seats.
« on: 20 May 2009, 04:22 »
Hi all. I have the recaros in my 1.8t and my heated seats worked wen i bought the car on the way home.
The folowing day i fitted my sub in the boot which i had in my mk4 1.4. Since then my seats havent wrked and up until now i thought it may be coincidence that both my elements have gone at the same time. Evry other electrical thing is spot on. Has any1 had problem like this? Also just to add... My fuses are fine but sum1 at my wrk said. That there is a fuse under the seat but i havent heard bout that. Sorry for the masive post ha ha. One more thing wen 4 fitted my wires through i took out my glove box and at the top underneith my actual dash theres a plug which isnt pluged in. Have i knocked this out or sumthin takin tge glove box out. Fort it may have sumthin do with dat or the passenger air bag. Any help would b appreciated.Cheers manny
Offline manny2k80uk
Re: Heated seats.
« Reply #1 on: 22 May 2009, 20:25 »
Can no1 help?
Offline mikemk4gti
Re: Heated seats.
« Reply #2 on: 22 May 2009, 20:28 »
I have the same problem, both seats don't work.
If you look under the seat there is a green plug, you could check if you are getting power to the seats there with a meter.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline spetzdude
  • I Bleed Blue!
Re: Heated seats.
« Reply #3 on: 22 May 2009, 20:29 »
cant help you mate but i have the same problem.
the car has done 37000 miles when i brought it, and since then it has never worked, checked all fuses but nothing.
Performance mods: Revo stage 2 map, 5 Peice Hose Kit, TIP, evoloution motorsport air filter, N249 by-pass, Forge spliter valve, lowerd 50mm (KW), Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
Cosmetic mods: Tints,De-wiperd the rear, De-badged front grill, Sharan rear badge, Rear spoiler, 4mo rear valance, 4mo front spliter, arero wipers, stubby areial, DOTZ 18" Alloys, Boost guage, Smoothed Bumbers, ECS N75 Vlalve.
BHP: 231
TRQ: 341.3
Offline kazaaa
Re: Heated seats.
« Reply #4 on: 22 May 2009, 20:35 »
Hi mate,
I'm on the same boat. car has done 33K, but the passenger side heated seat has stopped working  :embarassed:
Offline kevin31
Re: Heated seats.
« Reply #5 on: 26 May 2009, 13:29 »
Guys,
Im new to this forum! Picked mine up saturday 1.8t 150bhp great car this is my first golf and very impressed so far.
I to have bot heated seats not working? Any ideas?
Thanks
Kev
1999 Golf GTI MkIV 1.8T 20V AGU
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Heated seats.
« Reply #6 on: 26 May 2009, 13:36 »
as said check for voltage at the plugs to see if you have power there, if you do you know it's the fault of the heating elements (very common)
Offline kevin31
Re: Heated seats.
« Reply #7 on: 26 May 2009, 13:41 »
thanks!
Guess you disconnect the batterry before unplugging the connector from the seat?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Heated seats.
« Reply #8 on: 26 May 2009, 13:46 »
no you should be ok, just make sure you don't disconnect the airbag one by mistake (yellow one)
Offline Rhyso
Re: Heated seats.
« Reply #9 on: 26 May 2009, 13:49 »
also if you disconnected the battery how would you check for power........
