Author Topic: wishbones  (Read 2265 times)
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
wishbones
« on: 10 August 2004, 18:14 »
hi can anyone help me or point me in the right direction on how to fit wishbones please because the haynes manual is sh!te
thx
marco
Offline KelvinIOW
Re:wishbones
« Reply #1 on: 13 August 2004, 19:42 »
Ive just replaced my drivers side wishbone as i had an accident and bent it!
Im telling you ive never done it before but the haynes manual is absoloute sh!te.
So i just went for it i managed to do it in this order;
Take wheels off
remove the rubber piece from the end off the anti roll bar.
undo all the bolts under neath the wishbone.
The must trickiest bit is trying to get the metal sleeve out from one of the bushes, the haynes manual says that it comes of with the bolt but mine didnt, i think that if you were not to spray it with wd40 like i did then it might have a chance of comming out.
But if it doesnt come out then you have to try and pull it out with some pliers but be patient it will come out, just dont loose your rag like me!!
once this metal sleeve is out you can then pull the wishbone free with a bit of wiggling and there you go!!
It is a Bast##d of a job but it would be costly to get others to do it and its allways good to give it a go so good luck mate hope you get on all right 8)
Offline marcogolfo
Re: wishbones
« Reply #2 on: 16 August 2004, 22:30 »
thanks mate i have managed to get one sid edone and they are a bastard to get out
marco :o
Offline KelvinIOW
Re: wishbones
« Reply #3 on: 17 August 2004, 17:06 »
Did u make a mess of the metal sleeve within the wishbone to be able to get it out if so if u need a new one ive ordered 2 of them cos i new u were doing the same repair if u need one give us a shout all send it to u it only cost 18p so i dont want anything for it!
It just nice to help out if u can
let me know if u need the metal sleeve to go into the wishbone bush
Respect!
golfvr6
Re: wishbones
« Reply #4 on: 17 August 2004, 17:46 »
The sleeve doesn't come out with the bolt, break it  ;)
Offline richandhazel
Re: wishbones
« Reply #5 on: 17 August 2004, 18:11 »
Is it like the Audi's where you must tighten up the bolts with the weight of the car on? Otherwise you'll wear the new bushes out in no time.
golfvr6
Re: wishbones
« Reply #6 on: 17 August 2004, 18:27 »
Yes you are supposed to tighten the bolts with the car back on the floor.
Offline KelvinIOW
Re: wishbones
« Reply #7 on: 17 August 2004, 23:03 »
I didnt know that so thanx for the use full info
Offline marcogolfo
Re: wishbones
« Reply #8 on: 26 January 2005, 11:03 »
Lol just read your post mate.  I hope you got your wish bone done and thank you for the offer of the metal sleeve.  As it happened I did wreck one of them some time ago when i did it but managed to do alright.  They were a bastard to get out and refit.  The problem I'm having now though is that its cronking like hell because i never put a metal sleeve3 in one side.  RESPECT
Take it easy
regards
mnarco
