Author Topic: indicator fault  (Read 686 times)
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
indicator fault
« on: 19 May 2009, 21:29 »
i have noticed that when my car is running the small green indicator light is dimly lit, it is on all the time, the indicators work fine and the light also flashes nice and bright when indicators are used, just wondered if there was a common fault or if i had a light that was back feeding?? if so how would i find the fault?
many thanks
will
sorry should have mentioned it's an 86' mk 2 gti
Offline Ben Lessani
Re: indicator fault
« Reply #1 on: 19 May 2009, 22:26 »
Usually its a sign of a loose/faulty hazards switch - or a blown indicator fuse.
Or old crappy alarm wiring.
Re: indicator fault
« Reply #2 on: 20 May 2009, 18:58 »
cheers ben, will check hazard switch, like i say the indicators work fine so couldn't be a fuse, i've just had a spurious alarm removed and a thatcham cat 1 alarm and imobiliser fitted and it's no different.
i'll look tomoz when i get my car back from paintshop
