Author Topic: horney - "mkII Gti 8v Track Toy"  (Read 74017 times)
Offline Horney
Re: horney - "mkII Gti 8v Track Toy"
« Reply #60 on: 23 September 2012, 18:18 »
Been a awhile since I updated this!
Cage is pretty much in and just needs some slight adjustment.
It's booked in for paint in the 1st week of november and I have the week off to help. Before then I need to finish the cage fitment, fab up the seat mounts and weld those in and finish the sunroof patch.
I've ordered a polycarb rear screen and a new on for the passenger side to match the drivers side one. Just need to pick up a new windscreen before November so I can make it water tight after the paint has been applied.
Then I just have to bolt it all back together and put it in for an MOT. :grin:
Nick
Offline Horney
« Reply #61 on: 05 November 2012, 20:11 »
GOt a week off to try and get the car painted.
Untitled by Nicholas R Horne, on Flickr
Day 1 done.
Offline Horney
« Reply #62 on: 06 November 2012, 20:09 »
Day 2
At some point the rear panel had been replaces (badly) and the seams filled. When I ground it all back it was horrid mess, Marcus cut, ground, welded and fabricated new seams.
Spot welding sunroof panel
Nick
Offline Horney
« Reply #63 on: 08 November 2012, 22:21 »
All the cage mounts are now boxed off and finished
Front valance prepped for primer
Underseal removed with an air chisel.
Priming bits
Hung out to dry
Offline Horney
« Reply #64 on: 18 November 2012, 21:38 »
Another weekend, more progress.
underseal removed:
Roof needed some bracing to stop it flopping about after removal of the sunroof and it's mechanism:
Spare dash for flocking by The Flock Shop:
A windscreen to pop in while the clear one I want is on back order:
Rear strutbrace and badge ready for primer:
New front valance with some stonechip applied:
Flatting back first coat of primer on the bonnet:
A selection of flatted panels awaiting coat 2 of primer:
Needed to hang the wings somewhere for the primer to dry!:
Many primered panels!
That's it for another weekend.
Nick
Offline Horney
« Reply #65 on: 22 December 2012, 22:34 »
So......er.....yeah. Got fed up of trying to rebuild the roof with filler after warping it.
Fibreglass roof panel incoming!
Nick
Offline Horney
« Reply #66 on: 23 December 2012, 18:03 »
A better picture of the roof chopped out
Masked up the back end for some primer
Primer going on
Primered
Next weekend I want to prime the front half of the car and paint the wings, bonnet and boot white.
Nick
Offline Horney
« Reply #67 on: 03 January 2013, 21:47 »
Incoming!
Nick
Offline Horney
« Reply #68 on: 06 January 2013, 16:21 »
Fibreglass roof collected yesterday from LWS Designs. A top couple of chaps making very good products. The roof is work of fibreglass art and not your usual ton of matting with gaps you could drive a bus through etc.
Anyhoo, here it is placed on the car un-trimmed:
IMG_0200.jpg by Nicholas R Horne, on Flickr
It's a bout 1.5mm thick as can be seen here:
IMG_0202.jpg by Nicholas R Horne, on Flickr
The underside shows how it's made from a big sheet of glassfibre weave so even the inside has a nice uniform finish to it:
IMG_0203.jpg by Nicholas R Horne, on Flickr
The back end (it needed pulling back a bit, it does actually fit perfectly) and the quality of the gel coat finish:
IMG_0205.jpg by Nicholas R Horne, on Flickr
Got trimming and tried a short section of the gutter trim back on to make sure it would fit without me having to take mor eof the roof back. It does fit. Result:
IMG_0209.jpg by Nicholas R Horne, on Flickr
Front corner (Trim not actually put in properly, just draped):
IMG_0210.jpg by Nicholas R Horne, on Flickr
All trimmed up and ready to be bonded on:
IMG_0212.jpg by Nicholas R Horne, on Flickr
I just need to prep the shell and buy the sealant and we're good to go!
Nick
