Author Topic: Problem of my own doing  (Read 1850 times)
Offline Ben Lessani
Re: Problem of my own doing
« Reply #10 on: 21 May 2009, 13:24 »
Where did you put it, oil cooler or head? Sticking it in the wrong place the first time might have broke it?
However, if the fan effects it, sounds like your wiring is wrong! Earths +ve feeds, sensor lines etc.
Offline baronvontinkle
« Reply #11 on: 21 May 2009, 22:39 »
I'll have to get it out and have a look at the wiring then. I'm abit stumped myself. I'll check everything over this weekend to make sure everything is as it should be
Offline Ben Lessani
« Reply #12 on: 21 May 2009, 22:58 »
« Reply #13 on: 22 May 2009, 13:24 »
Put it in the oil cooler first time and thats where its supposed to be
Offline Ben Lessani
« Reply #14 on: 22 May 2009, 16:42 »
The 0.3 bar sensor goes in the head - not the cooler, so no suprise it doesn't work.
The 1.8 bar sensor goes in the oil cooler.
« Last Edit: 23 May 2009, 02:19 by Ben Lessani »
« Reply #15 on: 23 May 2009, 15:40 »
Just read through the thread and it seems i forgot to tell you. Turned out i had the 1.8bar. Sorry for the confusion.
