Poll
can you run a mk1 golf gti fuel pump without the accumulator ??will it be ok
mk1 fuel pump
1 (25%)
help
3 (75%)
Total Members Voted: 3
Author Topic: 1.8 16v kr running probs now with vid  (Read 9709 times)
Offline raferackstraw
Re: mk1 1.8 16v fueling running probs
« Reply #30 on: 03 September 2009, 14:11 »
sorry mate but if captain picard is in despair i d say you've definintely f00ked the metering head
again, it is critical clean fuel is delivered to the m/head and injectors
i guess you wont make the mistake of running without a fuel filter again
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline tamthebam16v
1.8 16v running probs
« Reply #31 on: 03 September 2009, 17:48 »
  YEP :laugh: going to get another meteringhead soon fingers crossed that will fix it + ill put a fillter on first just in case  :rolleyes:
« Last Edit: 02 November 2009, 09:19 by tamthebam16v »
« Reply #32 on: 31 October 2009, 21:41 »
got another metering head and it was still the same so i pulled the brand new injectors out and turned the fuel pump on and lifted the mettering flap up and nothing so i put the old injectors back on and they sprayed fuel  :shocked: so put them in and she runs and revs  :grin: she needs set  up as she is slow as sh.it  :cry: but at least she is going now  :cool: so the brand new injectors are ether wrong ones or faulty so £140 for nothing + all the other things i bought all in about £400 for nothing
« Reply #33 on: 01 November 2009, 12:40 »
heres a vid of how she runs still not right any ideas #??
Re: mk1 1.8 16v fueling running probs now with vid
« Reply #34 on: 01 November 2009, 13:13 »
does sound like it only running on 3cyl have you double checked ignition timing? make sure you got a spark on all plugs
maybe cam timing out?
« Reply #35 on: 01 November 2009, 15:21 »
runs on four when ticking over getting spark on all four to, do you think the hall sender could cause this ??
« Reply #36 on: 01 November 2009, 17:38 »
try ignition module, its a small square box that screws to the top of the ecu
there is atest for it with a multi meter, do a search for 16v misfire on here
« Reply #37 on: 01 November 2009, 17:40 »
ok m8
Re: 1.8 16v kr running probs now with vid
« Reply #38 on: 03 November 2009, 14:47 »
i took the brand new plugs out and they where sooty all of them and they where only in the car one day no miles only ticking over and a little reving so think its defo fueling
« Reply #39 on: 14 December 2009, 14:35 »
anyone ??? santa plz fix ma car you robbing basterd :cry:
