Poll
can you run a mk1 golf gti fuel pump without the accumulator ??will it be ok
mk1 fuel pump
1 (25%)
help
3 (75%)
Total Members Voted: 3
Author Topic: 1.8 16v kr running probs now with vid  (Read 9706 times)
Offline raferackstraw
Re: mk1 1.8 16v fueling running probs
« Reply #20 on: 02 September 2009, 15:24 »
i'm sure there was a similar post on mk1golf forums and it turned out that there was a shim missing from the pressure regulator in the metering head
maybe swop the pressure regs over first rather than change m/head?
did the metering head that you changed come from a working car?
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline tamthebam16v
« Reply #21 on: 02 September 2009, 15:30 »
i put more chims in the pressure regulator and tryed less but made  no diferince  to it
metering head i go was ment to be good  :embarassed:
« Reply #22 on: 02 September 2009, 16:17 »
mmmh i had a gander on clubgti and there was athread where a guy had changed his injectors, but the new injectors did not have the silver 'caps' on them, so he swapped them them over from the old ones, but it turns out the bosch techy he took it to removed 'caps' and car ran fine
have a look over on clubgti and do search of 16v fuelling
really you need pressure guage to diagnose fault otherwise its gonna be very hit and miss, oh and try a brand new fuel filter in case other one has been partially blocked
« Reply #23 on: 02 September 2009, 16:34 »
no fuel filter on it yet  :laugh:
« Reply #24 on: 02 September 2009, 17:10 »
no fuel filter?  :huh: what its never had one ?  :huh:
« Reply #25 on: 02 September 2009, 18:15 »
after i put the new fuel tank + filler neck + fuellines on and new injectors so there will not be any sht in the tank so no filter yet i will put one on but trying to get it running right first
THE CAR WAS A 83 1.1 C WHEN I GOT IT :grin:
« Last Edit: 02 September 2009, 18:22 by tamthebam16v »
« Reply #26 on: 02 September 2009, 18:23 »
 i dont think petrol is 100% clean you know, as in there is gonna be the odd particule or dirt etc in it after all the underground storage tanks do corrode
maybe by not running a filter all you have done is blocked the metering head or injectors again
« Reply #27 on: 02 September 2009, 18:56 »
did all the work i about 2 weeks so didnt think i could be blocked all alreadl  :embarassed:
« Reply #28 on: 03 September 2009, 10:57 »
« Reply #29 on: 03 September 2009, 11:38 »
 :sick: :sick: :sick: :cry: :cry: :embarassed: :embarassed: :embarassed: :rolleyes: HOPE NOT  :sick: :cry: :cry:
