Author Topic: relay for electric window  (Read 2240 times)
Offline philip_felop
« on: 09 August 2004, 16:53 »
Hi
have a P-reg 8v and the drivers side electric window works no more. it looks as though the relay attached to the motor is at fault.
getting hold of a second hand motor is a real problem, have tried find-a-part. co.uk etc but the cheapest i have found is ?75, all for a poxy relay. I would even fit a new relay to the circuit board if I could buy one but maplin don't supply.
Any ideas?
redcarboy
Re:relay for electric window
« Reply #1 on: 09 August 2004, 21:44 »
Prob best looking round local scrappers first or put a message in parts wanted see if anyone looking through the parts section can help. ;D
Offline Gary17
« Reply #2 on: 09 August 2004, 22:21 »
try sanburn autos are brilliant this is the number 02476637376 they allways have everything ive needed good luck !!
Offline J-man
« Reply #3 on: 11 August 2004, 08:08 »
I'v got the same problem. Having a hard time finding a new one.
I know there is the motor for driving the window up and down but what you you call the runners/cable that join it all together? (sorry for the stupid question) its just that I need the whole lot and not sure what im meant to be asking for. Is it the motor and regulator  or window mech, motor and regulator?
He who laughs last........Thinks slowest
« Reply #4 on: 11 August 2004, 10:56 »
the regulator is the mechanism cables etc. (so i've been told)
the latest is I've found a supplier for the new relay go to www.rswww.com and look for
cat number 434-9292 Its ?11 including delivery, all that needs doing is soldering it to the circuit board. the pins don't line up so you will have to solder wires to it but if you use little leads with crimp spade plugs on the end then you can play about if
you get them wrong.
Alot cheaper and not too difficult for anyone that can use a soldering iron.
