Author Topic: Touch up spray  (Read 10072 times)
Offline gibson
Touch up spray
« on: 09 August 2004, 15:31 »
Like a complete tw@t, I decided to rid all rust on me car. Ok that was fine, bodged up all looking good, However I have tried many different spray paints and after perfect priming I knack it up with the black paint. It just doesn't match the rest of the car, Any ideas what cost it would be to get the back quarters resprayed or am i going to have to get the full car done to match??
Offline AdamB
  • The Perfect Storm
Re:Touch up spray
« Reply #1 on: 09 August 2004, 16:44 »
A good sprayer should be able to do the lot for a couple of hundred, with a good match.
I don't own this anymore - I just can't be arsed to change the picture
Offline 8valvesgood
Re:Touch up spray
« Reply #2 on: 09 August 2004, 17:55 »
There are many different variations of paints including types of black. Depends what paint your using if your using the stuff out of a can in halfords then it won't work, whatever they say this kind of spraying is only for small areas. You need to apply a decent coat of lacquer in order to bring depth to the colour, if you just spray it it wont match at all.
Ideally if your doing it your self you should get the paint mixed at a proper car paint specialist and apply it using a compressor spray cans contain hardly enough paint to build up a good strong layer.
?200 tops for the back quarters.
« Last Edit: 09 August 2004, 17:56 by 8valvesgood »
You can't polish a turd
Blue MK2
Re:Touch up spray
« Reply #3 on: 09 August 2004, 22:52 »
i had my rear left quater done by a top specialist. The paint came out slightly darker and nothing could be done about it. although no one else could spot it..........I f**kIN COULD >:(
Respray would be better off but as its black you might just be lucky.
Offline gibson
Re:Touch up spray
« Reply #4 on: 10 August 2004, 08:17 »
ok, thanks. I might go for a full respray. No one likes a copy-cat but i may go for the colour on blue MK2, It looks great although i don't know yet?? I like it in black as it is
Blue MK2
Re:Touch up spray
« Reply #5 on: 10 August 2004, 10:06 »
lovely colour isnt it ;)
ill pm u the paint coe if you like
Offline gibson
Re:Touch up spray
« Reply #6 on: 10 August 2004, 11:19 »
yeah plz mate. How much did that cost you?
Blue MK2
Re:Touch up spray
« Reply #7 on: 10 August 2004, 11:54 »
1.1k. seems expensive but it had alot of prep work to do so that added up.
paint code... LP5U
Blue
Offline topher
  • Administrator
  • fully functioning
Re:Touch up spray
« Reply #8 on: 10 August 2004, 14:07 »
a colour change respray is expensive to do properly, sure you can just spray the outside but everytime you open the door of lift the bonnet you'll be reminded it wasn't done properly. worth considering  ;)
« Last Edit: 10 August 2004, 14:08 by tophuh »
Offline gibson
Re:Touch up spray
« Reply #9 on: 10 August 2004, 15:07 »
fookin ell 1.1k..... Nah Ill stick to black wit black... hope it wont cost a bomb. Taking it for a price at the local coachworks tomorrow
