Author Topic: Lowered, ARB joints rubbing inside of wheel?  (Read 1449 times)
Offline Richard Andrews
« on: 16 May 2009, 17:40 »
Spec as per signature, even with coilovers wound all the way up ARB joints are rubbing inside of wheel!
Spacers?
« Last Edit: 16 May 2009, 17:50 by Richard Andrews »
1996 3d VR6 BLACK HIGHLINE.
Offline spunkymonkey
  • Tepidly moist! That's what that is!
Re: Lowered, ARB joints rubbing inside of wheel?
« Reply #1 on: 16 May 2009, 19:46 »
Yes just a couple of mm will do it.
« Reply #2 on: 16 May 2009, 22:07 »
cheers, where is cheapest place for spacers?
Offline Adam
« Reply #3 on: 17 May 2009, 01:00 »
Did you get your camber set? Sounds like you have a bit of camber problems. I had the opposite and put a nice grove in my new Toyos  :cry:
Down Hill From Here.
« Reply #4 on: 17 May 2009, 11:33 »
PICS?
« Reply #5 on: 17 May 2009, 14:39 »
spacers £40 a pair? WTF!
Offline Mikester
  • Civic Type R
« Reply #6 on: 17 May 2009, 14:44 »
what wheels are u using? with what et?
Im with the camber idea too
« Reply #7 on: 17 May 2009, 14:50 »
ah, Grayston via Larkspeed, £25 for a pair of 9mm spacers and bolts.
Its not the camber, the wheels are perfectly lined. It is the ARB, I can see from under the car, its cause I am using such low profile tyres. I need to push the wheels out anyway so 9mm will look smart and allow the wheels to rotate freely without catching the ARB.
Offline Mikester
  • Civic Type R
« Reply #8 on: 17 May 2009, 15:06 »
Do they come with the longer bolts you need to put through the spacer?
« Reply #9 on: 17 May 2009, 17:14 »
yep.
