Golf mk2
Speedometer info.........
Topic: Speedometer info......... (Read 1074 times)
Maltman
15 May 2009, 23:35 »
Can someone tell me what is the 'correct' speedometer unit for a '91 8v model. Mine has a 140mph max figure on the dial and I believe it is the original unit.
I'm looking for a 'correct' set of replacement clocks and have been offered a single plug (correct) set but with a speedo that has a 120mph max reading.
Am a bit confused with the various alternatives....
Any info help gratefully received.
M.
danny_p
Forum addict
Re: Speedometer info.........
16 May 2009, 00:38 »
iirc you can fit any clocks from a gti to another gti as long as they are both on the same electrical system ( 1 or 2 plug )
you have to make sure the clocks have the same internal gearing as some cars din't eg syncros there clocks read way off on a gti. but pritty sure all the gti's have the same gering in the clocks check the 4 digit number at the bottom by where it says vdo
all the VW's have gone bar 1.
twistedblack69
Proud mk2 user and abuser
16 May 2009, 01:04 »
I think the 140mph clocks were for the 8v GTI, the 120mph clocks were for the Drivers/Ryders, and I think possibly pre-90 GTIs and the 160mph clocks were for the 16v GTIs.
nealey
16 May 2009, 19:23 »
they can be either 120mph or 140mph, 16v's came with 160mph clocks
As said previously as long as the internal gearing is the same and they have the same number of plugs they will work
Maltman
18 May 2009, 09:05 »
Many thanks for your replies... presumably I will know if the gearing is the same by the code numbers on the bottom of the unit.
M.
Golf mk2
