Author Topic: radio to headlight (electrical)  (Read 1014 times)
Offline boxer1968
« on: 14 May 2009, 22:37 »
hello all
has any one had this b4 looked at seach didnt find any help
ive wired in a radio to my car mk2 16v 91 it semed to work fine till i drove car at night switched light on radio goes quite move dimmer to the left ie dim instrutment lights radio fine changed headlight switch still the same rechecked radio wires is there a relay linking both , when i bought the car i turned lights on and the loom caught light by fuse box(replaced loom) but it didnt seem to affect the fuse box  will be changing fusebox next to try to sort this any one have any ideas whats causing this.thanks in advance .max
Offline Thom89
  • Looking for an "Icebreaker"
Re: radio to headlight (electrical)
« Reply #1 on: 14 May 2009, 23:23 »
Any chance of that in English, with punctuation... :wink:
Tom
Offline Mr Blue
« Reply #2 on: 14 May 2009, 23:36 »
Cant quite work out what your saying here but my guess is that your headunit is wired with the dimmer wire which isnt a fault.
check the manual and snip the dimmer wire and that should sort it
Offline l333
  • mk2 8v....mk3 8v....mk3 16v.... who says im greedy
« Reply #3 on: 15 May 2009, 00:03 »
hi dimmer wire shouldnt affect volume on a headunit. if u have wired the headunit in yourself make sure u havnt wired the sterio earth to the dimmer wire
have seen that before
Offline boxer1968
« Reply #4 on: 15 May 2009, 00:39 »
ok il wire in a new earth .and see how that goes, cant understand how radio earth can be connected to dimmer but slowly will work though issues with the wires as guy i bought it from seems to have butchered it  :smiley: thanks for the replys will crack on tomorrow.max
« Reply #5 on: 15 May 2009, 08:14 »
check any grey/whitre wires behind the radio, and chop anythat have ended up wired to dash. you want red (live) and brown (earth)
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #6 on: 15 May 2009, 09:32 »
hello all
LOL @ this..
Offline boxer1968
« Reply #7 on: 16 May 2009, 12:57 »
ok found the offendending wire grey/blue dissconnected it, radio now fine all six speakers work fine dimmer works thanks for the replys till next time.max
Offline wampablo
  • 2nd mk4
« Reply #8 on: 16 May 2009, 14:19 »
ive done this a few times while in the wrkshop in the past. makes you feel like a right numpty lol
