Author Topic: g60 discs on a mk1  (Read 4552 times)
Offline geeza
g60 discs on a mk1
« on: 08 July 2003, 16:42 »
couple of years ago i bought a pair of spacer brackets to fit G60 discs to a mk1 using the standard calipers.
now i have finally got round to fitting them, problem is they move the caliper too far back so that one of the pads will no longer fit in.
the spacer plates are totally flat (there's no step to make up the distance) the same as any other that i have seen at inters.
am i missing something here? has anyone fitted a TSR kit? what do those brackets look like? ???
Offline geeza
Re:g60 discs on a mk1
« Reply #1 on: 08 July 2003, 23:46 »
hmm, i was affraid someone would say that. dont suppose you know if the hub carriers on a mk1 are the same as those used on a corrado or golf g60?
Offline modulater
« Reply #2 on: 24 July 2003, 22:25 »
No the hubs are different, even the early mark 2 golfs (before '89/90) need to have the hubs and bottom ball joints changed to fit the G60 hubs. Your best bet would be to fit audi coupe caliper carriers and 16V calipers and discs as this would upgrade you to 256mm over your present 239mm and as david dikinson would put it. it  would be "cheap as chips"
Offline Leew
« Reply #3 on: 29 July 2003, 10:19 »
Would 256 disks fit 14" wheel?
Offline dorsetdumplin
« Reply #4 on: 29 July 2003, 12:26 »
just chang the master cylinder mate disks wont give you the power you need.....
ive changed mine and found that i can stop quicker than my mum's new civic v-tec and shes has ABS
i have kept to standard drums on the back and gone for black diamond on the front
