Author Topic: need help asap  (Read 2177 times)
Offline Mikey_B
need help asap
« on: 14 May 2009, 10:41 »
right had my golf 1.6 for 3months now and a few days ago i noticed an oil leak where i park my car, i checked the oil levels and they are fine. then the following day i noticed a odd whinning noise when i accelerate then on top of that yesterday driving home on the motorway driving at 65-70mph it slipped out of 5th gear a number of times and i had to hold it into gear. also this morning had to hold it into 5th gear again. its only on the 5th gear. all other gears are fine.
This mean im in need of new gearbox?  :sad:
cheers
Mikey_B
Offline T_J_G
Re: need help asap
« Reply #1 on: 14 May 2009, 10:44 »
The chocolate gear box of the 1.4's and 1.6's strike again?
Offline Mikey_B
Re: need help asap
« Reply #2 on: 14 May 2009, 11:00 »
so what do you think people?  :sad:
Offline Mikey_B
Re: need help asap
« Reply #3 on: 14 May 2009, 14:05 »
anyone????
Offline Rhyso
Re: need help asap
« Reply #4 on: 14 May 2009, 14:08 »
knackered gearbox as Tim said
Offline Mikey_B
Re: need help asap
« Reply #5 on: 14 May 2009, 16:23 »
cheers  :cry:
Offline Ant1981
  • Feed me, prod me
Re: need help asap
« Reply #6 on: 14 May 2009, 17:51 »
Sounds like the differential bearings have knackered, leaking oil out. You can actually get the box reconditioned to a very good standard for about the same price I've seen some 'supposedly reconditioned' boxes offered for.
'09 Kawasaki Ninja ZX-6R
Offline linz
  • vee-dub
Re: need help asap
« Reply #7 on: 14 May 2009, 20:09 »
yep sounds like the differential has gone from 4th to fith so you may need to get that sorted or prob cheaper jus to get a second hand box
Offline Ant1981
  • Feed me, prod me
Re: need help asap
« Reply #8 on: 14 May 2009, 20:30 »
'Differential has gone from 4th to fith'?  :huh:
You only get one differential per pair of wheels that drive the vehicle. The bearings on the differential have are likely to have worn.
Yes it's cheaper to get a second hand box, but you get what you pay for and what do you actually want? Your box could have been second hand if you sold it to someone, and look what's happened to it.
Get a recon at the very least.
Offline northeast_gti-t
  • "1.8T AGU"
Re: need help asap
« Reply #9 on: 15 May 2009, 02:56 »
possibly that the 5th gear cog has broken/chipped its teeth as said i would look for a recon box rather than repair sooner or later if the teeth from the gear are floating around in the gear oil it wont do the rest of the gearbox any good if debris get around the lay shaft and main shaft and syncros  :cry:
2000 Mkiv GTi 1.8T AGU
