Author Topic: mk1 dash  (Read 1841 times)
Offline M41K1T
mk1 dash
« on: 08 August 2004, 12:04 »
Does n e 1 know how 2 take the dash out?
and the bar behind the rear seats is that there 4 any reason or can i cut it out?
Offline 8valvesgood
Re:mk1 dash
« Reply #1 on: 08 August 2004, 16:21 »
depends what MK1 it is. If its a cab leave well alone thats the strength to the car.
You can't polish a turd
Offline carrie
  • i can see into your soul and its not good
Re:mk1 dash
« Reply #2 on: 08 August 2004, 21:50 »
what part od the dash?
as 8v said never touch that bar on a cab or you will kill it on the first bump you hit
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
Offline M41K1T
Re:mk1 dash
« Reply #3 on: 09 August 2004, 00:13 »
yeah it is a cab, wont b taking that out.
i want 2 take out the dash so i can spray it white and fit some other bits on it
Offline 8valvesgood
Re:mk1 dash
« Reply #4 on: 09 August 2004, 00:46 »
two bolts either side of the black top part of the dashboard youll see them when you open the doors in the corner. the trim at the front needs to come off, cross head screwdriver. the bottom section that covers the front bar is kept in place by black circular clips, push the inner bit out there are about 8 of em scattered around, remove them and the bottom section will come off.
Offline M41K1T
Re:mk1 dash
« Reply #5 on: 10 August 2004, 12:46 »
cheers mate
