Golf mk2
Crank oil seal leak?
Topic: Crank oil seal leak? (Read 2125 times)
bmouthboyo
Here all the time
13 May 2009, 22:29 »
Hi again guys,
Just trying to locate the cause of this leak.
Could it be some kind of seal?
Easy fix?
cheers
l333
GTI forum regular
mk2 8v....mk3 8v....mk3 16v.... who says im greedy
Re: Crank oil seal leak?
13 May 2009, 22:39 »
best thing to do is take the timing belt covers off and have a good look and do the cam belt while ure there should be able to do that in an hour easy
Wayne
Sir Postalot
14 May 2009, 00:04 »
Worth remembering that as well as the crank seal the housing has a gasket behind it, biggest issue is removing the housing without damaging the sump gasket.
bmouthboyo
Here all the time
21 May 2009, 10:21 »
Is it a big job to replace the crank seal gaskets and sump?
Wayne
Sir Postalot
21 May 2009, 10:26 »
Quote from: bmouthboyo on 21 May 2009, 10:21
Not really, going to be a bit messy but easy enough to sort.
Golf mk2
